									Stain application - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-application/</link>
            <lastBuildDate>Wed, 28 Oct 2026 08:11:58 +0000</lastBuildDate>
                        <title>RE: Stain application</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-application/#post-14552</link>
                        <pubDate>Sat, 22 Jul 2023 11:44:28 +0000</pubDate>
                        <description><![CDATA[Two coats applied wet on wet for the horizontals and one coat for the verticals is okay. See some TWP tips here:]]></description>
                        <content:encoded><![CDATA[<p>Two coats applied wet on wet for the horizontals and one coat for the verticals is okay. See some TWP tips here:</p>
<p>https://twpstainhelp.com/twp-stain-wet-on-wet-application/</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-application/#post-14552</guid>
                        <title>Stain application</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-application/#post-14550</link>
                        <pubDate>Fri, 21 Jul 2023 21:10:27 +0000</pubDate>
                        <description><![CDATA[1000 sq ft redwood deck (3 years old)
properly stripped and brightened with RAD products
L shaped deck with mostly 20 ft +/- boards spanning 17 to 34 boards across
When staining with TWP ...]]></description>
                        <content:encoded><![CDATA[<p>1000 sq ft redwood deck (3 years old)</p>
<p>properly stripped and brightened with RAD products</p>
<p>L shaped deck with mostly 20 ft +/- boards spanning 17 to 34 boards across</p>
<p>When staining with TWP 1502, should I stain each individual board from end to end before beginning adjacent board(s)?</p>
<p>What is the time frame to apply second coat using wet on wet method?</p>
<p>Is it necessary to apply two coats to any vertical surface such as built-in planter boxes or benches?<br /><br /><br /></p>
<p>Thank you.</p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>dthefox</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-application/#post-14550</guid>
