									Solid stain applied and cured- added sealant on top, now have white blotches? - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-applied-and-cured-added-sealant-on-top-now-have-white-blotches/</link>
            <lastBuildDate>Wed, 30 Sep 2026 15:57:38 +0000</lastBuildDate>
                        <title>RE: Solid stain applied and cured- added sealant on top, now have white blotches?</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-applied-and-cured-added-sealant-on-top-now-have-white-blotches/#post-13480</link>
                        <pubDate>Tue, 25 Aug 2020 16:05:50 +0000</pubDate>
Ok, thank you!]]></description>
                        <content:encoded><![CDATA[<p>@administrator</p><p></p>
Ok, thank you!]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>andersonm</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-applied-and-cured-added-sealant-on-top-now-have-white-blotches/#post-13480</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-applied-and-cured-added-sealant-on-top-now-have-white-blotches/#post-13479</link>
                        <pubDate>Tue, 25 Aug 2020 16:03:01 +0000</pubDate>
                        <description><![CDATA[Sealers seal unstained wood, never stained wood. Also, deck stains have water repellent properties as well so no need.]]></description>
                        <content:encoded><![CDATA[Sealers seal unstained wood, never stained wood. Also, deck stains have water repellent properties as well so no need.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-applied-and-cured-added-sealant-on-top-now-have-white-blotches/#post-13479</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-applied-and-cured-added-sealant-on-top-now-have-white-blotches/#post-13478</link>
                        <pubDate>Tue, 25 Aug 2020 15:53:37 +0000</pubDate>
That stinks!  So, what&#039;s the purpose of a sealant then if not to seal a stain?  The directions on the sealant said it could be applied on top of a stain?]]></description>
That stinks!  So, what's the purpose of a sealant then if not to seal a stain?  The directions on the sealant said it could be applied on top of a stain?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-applied-and-cured-added-sealant-on-top-now-have-white-blotches/#post-13478</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-applied-and-cured-added-sealant-on-top-now-have-white-blotches/#post-13477</link>
                        <pubDate>Tue, 25 Aug 2020 14:40:20 +0000</pubDate>
                        <description><![CDATA[You can never apply a sealer over a deck stain so you will have to remove it by stripping and or sanding. You will probably have to restain after as well.]]></description>
                        <content:encoded><![CDATA[You can never apply a sealer over a deck stain so you will have to remove it by stripping and or sanding. You will probably have to restain after as well.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-applied-and-cured-added-sealant-on-top-now-have-white-blotches/#post-13477</guid>
                        <title>Solid stain applied and cured- added sealant on top, now have white blotches?</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-applied-and-cured-added-sealant-on-top-now-have-white-blotches/#post-13476</link>
                        <pubDate>Tue, 25 Aug 2020 14:35:59 +0000</pubDate>
                        <description><![CDATA[Help!  We stained our deck with a solid stain and allowed it to cure properly.  Applied a clear sealant on top and shortly after application, white blotches started showing up.
What do I do...]]></description>
                        <content:encoded><![CDATA[Help!  We stained our deck with a solid stain and allowed it to cure properly.  Applied a clear sealant on top and shortly after application, white blotches started showing up.
What do I do now?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-applied-and-cured-added-sealant-on-top-now-have-white-blotches/#post-13476</guid>
