									Solid Stain Advice - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-advice/</link>
            <lastBuildDate>Mon, 12 Oct 2026 03:38:00 +0000</lastBuildDate>
                        <title>Solid Stain Advice</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-advice/#post-8386</link>
                        <pubDate>Mon, 03 Jun 2013 23:16:00 +0000</pubDate>
                        <description><![CDATA[You have a mess that needs to be removed and it seems the only way would be to sand it all off or replace the wood. I doubt strippers will be effective with this buildup that you have. The o...]]></description>
                        <content:encoded><![CDATA[You have a mess that needs to be removed and it seems the only way would be to sand it all off or replace the wood. I doubt strippers will be effective with this buildup that you have. The only othter option is to paint the deck. It will peel but it will at least look uniform.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-advice/#post-8386</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-advice/#post-8382</link>
                        <pubDate>Mon, 03 Jun 2013 19:46:54 +0000</pubDate>
                        <description><![CDATA[My inherited deck is a mess. Original deck was built using cedar and stained a dark, chocolate color using Behr Premium. When boards showed signs of rot, they were replaced with treated pine...]]></description>
                        <content:encoded><![CDATA[My inherited deck is a mess. Original deck was built using cedar and stained a dark, chocolate color using Behr Premium. When boards showed signs of rot, they were replaced with treated pine. So 1/4 of the current boards are pine, 3/4 are still cedar. At some point an attempt was made to bleach the dark stain away, so the wood under the stain is an off white color. I have tried to simply replicate the original dark color with the Behr stain; the results are terrible. Deck is located in WI. I have re-stained the deck each of the 3 years I have owned the home. Each spring, 50&#37; of the stain has peeled off and it looks like garbage. Is there any hope in trying to repair the deck to be at least semi-presentable? What steps would you advise?]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>buckydt</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/solid-stain-advice/#post-8382</guid>
