									Replacing Sikkens Cetol 1 &amp; 23 on Tongue/Groove Cedar Siding - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/replacing-sikkens-cetol-1-23-on-tonguegroove-cedar-siding/</link>
            <lastBuildDate>Sat, 07 Nov 2026 21:28:06 +0000</lastBuildDate>
                        <title>Replacing Sikkens Cetol 1 &amp; 23 on Tongue/Groove Cedar Siding</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/replacing-sikkens-cetol-1-23-on-tonguegroove-cedar-siding/#post-10367</link>
                        <pubDate>Mon, 07 Sep 2015 12:32:01 +0000</pubDate>
                        <description><![CDATA[Apply it with a sprayer then pressure wash off for best results. Should not be an issue with vinyl but test first. Careful that the stripper does not get on your back!]]></description>
                        <content:encoded><![CDATA[Apply it with a sprayer then pressure wash off for best results. Should not be an issue with vinyl but test first. Careful that the stripper does not get on your back!]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/replacing-sikkens-cetol-1-23-on-tonguegroove-cedar-siding/#post-10367</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/replacing-sikkens-cetol-1-23-on-tonguegroove-cedar-siding/#post-10363</link>
                        <pubDate>Sat, 05 Sep 2015 15:14:24 +0000</pubDate>
                        <description><![CDATA[Thank you - this is what i thought but always better to ask the expert - how well does the Restore a Deck work on a vertical service? - was planning on using my back pack garden sprayer to a...]]></description>
                        <content:encoded><![CDATA[Thank you - this is what i thought but always better to ask the expert - how well does the Restore a Deck work on a vertical service? - was planning on using my back pack garden sprayer to apply or is it better to mix it in with pressure washer given a vertical surface?  Any issues with Restore a Deck stripper and or brightener around Vinyl window trim (do i need to cover?  Again - a huge thanks]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>tkramesb</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/replacing-sikkens-cetol-1-23-on-tonguegroove-cedar-siding/#post-10363</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/replacing-sikkens-cetol-1-23-on-tonguegroove-cedar-siding/#post-10362</link>
                        <pubDate>Sat, 05 Sep 2015 12:06:58 +0000</pubDate>
                        <description><![CDATA[1. You need to remove 100&#037; if switching to another semi-transparent. If you want a solid opaque then you could clean and stain over it. There is no going back if you do this.
	2. Try a ...]]></description>
                        <content:encoded><![CDATA[1. You need to remove 100&#37; if switching to another semi-transparent. If you want a solid opaque then you could clean and stain over it. There is no going back if you do this.<br />
	2. Try a stain stripper and pressure washing to remove as much as possible, sand or scrape the est if needed after. Brighten all the wood when done. Use Restore A Deck Products.<br />
	3. TWP 1500 Series or Armstrong Clark. Darker or richer colors will always give better UV protection.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/replacing-sikkens-cetol-1-23-on-tonguegroove-cedar-siding/#post-10362</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/replacing-sikkens-cetol-1-23-on-tonguegroove-cedar-siding/#post-10361</link>
                        <pubDate>Fri, 04 Sep 2015 15:28:58 +0000</pubDate>
                        <description><![CDATA[Folks
	I have a Panabode cottage north of Toronto on the Kawartha lakes.  Cottage was built in the early 60&#039;s of 4 inch tongue and groove Cedar and over the years I have replaced the sta...]]></description>
                        <content:encoded><![CDATA[Folks<br />
	I have a Panabode cottage north of Toronto on the Kawartha lakes.  Cottage was built in the early 60's of 4 inch tongue and groove Cedar and over the years I have replaced the stain finish numerous times.  This usually entails hand scraping the boards back to bare wood.  Needless to say this is getting old.  I applied Sikkens Cetol 1 and 23 (semi transparent) about 20 years ago and it held up fairly well but eventually went hard, dark and started to flake.  I hand scraped it to bare wood again and used the same Sikkens process since it held up better than most other products we had tried in the past.  I am now at the point where the finish is hard again, dark and starting to flake.  I am not sure I want to go through the removal process again .. but I might have to.  Here are my questions.<br />
	1.  If I elect to go with an semi or full opaque stain do I still have to remove everything or what is the necessary prep for this given Sikkens would have been oil based (I believe).  What stain do you recommend?  If I have to drive to Buffalo and bring it back then I will consider making the trip for a good product.<br />
	2.  If I wish to punish myself and go through the removal process is there a decent stain removal product that will help lift the old Sikkens to make it easier to remove.  the reason for the hand scrape was "trying to hold a heavy belt sander against the siding for along period of time was tiring" and that did not solve for the rounded areas between the boards or corners.  A really sharp scraper and supporting grinder for sharpening worked better.<br />
	3.  I do like seeing the grain so a Semi-transparent is still preferred but once I have the finish off what do you recommend to replace the Sikkens ...that will hold up.  The side facing the water takes the heaviest UV hit. if I have to re-apply a coat of the recommended product every 3 to 5 years then I guess i can accept that (longer the better ... getting too old for this nonsense :))<br />
	Thanks and I look forward to your guidance]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/replacing-sikkens-cetol-1-23-on-tonguegroove-cedar-siding/#post-10361</guid>
