									Removing Solid Stain and Re-Staining - First Timer - Please help! - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/removing-solid-stain-and-re-staining-first-timer-please-help/</link>
            <lastBuildDate>Sun, 27 Sep 2026 03:27:56 +0000</lastBuildDate>
                        <title>RE: Removing Solid Stain and Re-Staining - First Timer - Please help!</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/removing-solid-stain-and-re-staining-first-timer-please-help/#post-14190</link>
                        <pubDate>Tue, 30 Aug 2022 16:07:21 +0000</pubDate>
                        <description><![CDATA[You cannot strip a solid stain fully so you will have to power sand or grind it off. Clean and brighten after a full removal.]]></description>
                        <content:encoded><![CDATA[<p>You cannot strip a solid stain fully so you will have to power sand or grind it off. Clean and brighten after a full removal.</p>
<p>https://www.deckstainhelp.com/how-to-sand-your-wood-deck/</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/removing-solid-stain-and-re-staining-first-timer-please-help/#post-14190</guid>
                        <title>Removing Solid Stain and Re-Staining - First Timer - Please help!</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/removing-solid-stain-and-re-staining-first-timer-please-help/#post-14189</link>
                        <pubDate>Tue, 30 Aug 2022 15:40:57 +0000</pubDate>
                        <description><![CDATA[Hi all – thank you for the resources, could use some guidance/sanity check my planned approach
We live in Toronto, Canada, purchased a house with a 300 sq ft deck, it was stained with a sol...]]></description>
                        <content:encoded><![CDATA[<p>Hi all – thank you for the resources, could use some guidance/sanity check my planned approach</p>
<p>We live in Toronto, Canada, purchased a house with a 300 sq ft deck, it was stained with a solid stain (unkn</p>
1410
1411
1412
<p>own), older wood, stain peeling, nails seems ok and floor is quite flat</p>
<p>Want to move to a clear or semi-transparent stain – Sansin Dec –</p>
<p>Curious on the process</p>
<p>1) Strip current stain with sander? thinking of using Diamabrush on angle grinder –</p>
<p>2) Is it easier to use a chemical stripper (before, after, or instead of sander)? or a large floor sander rental?</p>
<p>3) Clean and Brighten, is this needed?</p>
<p>4) Apply Stain once dry</p>
<p>Pictures below, main question is related to the recommended stripping/cleaning/brightening process,</p>
<p>what is the best option / sequence (diamabrush, floor sander, pressure washer, chemical stripper)</p>
<p>many thanks in advance</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>ah22</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/removing-solid-stain-and-re-staining-first-timer-please-help/#post-14189</guid>
