									Remove Sikkens sdr and replace with TWP 100 - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/remove-sikkens-sdr-and-replace-with-twp-100/</link>
            <lastBuildDate>Fri, 18 Sep 2026 01:10:01 +0000</lastBuildDate>
                        <title>Remove Sikkens sdr and replace with TWP 100</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/remove-sikkens-sdr-and-replace-with-twp-100/#post-9843</link>
                        <pubDate>Fri, 27 Mar 2015 17:41:05 +0000</pubDate>
                        <description><![CDATA[Use A stripper and pressure washer to remove. If needed you can sand with 60-80 grit after. Apply brightener when done. You do not need to tarp. Depends on which stripper you use it is a con...]]></description>
                        <content:encoded><![CDATA[Use A stripper and pressure washer to remove. If needed you can sand with 60-80 grit after. Apply brightener when done. You do not need to tarp. Depends on which stripper you use it is a concentration or not. RAD Stripper makes roughly 5 gallons.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/remove-sikkens-sdr-and-replace-with-twp-100/#post-9843</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/remove-sikkens-sdr-and-replace-with-twp-100/#post-9842</link>
                        <pubDate>Fri, 27 Mar 2015 16:58:44 +0000</pubDate>
                        <description><![CDATA[I live in western CO and have a covered deck that was stained with Sikkens SRD 5 years ago.  In the traffic areas the stain is worn off, but the verticals and low traffic areas still varying...]]></description>
                        <content:encoded><![CDATA[I live in western CO and have a covered deck that was stained with Sikkens SRD 5 years ago.  In the traffic areas the stain is worn off, but the verticals and low traffic areas still varying amounts of have failing stain.  I want to re-stain with TWP 100.  Should I clean, sand and re-clean, or would it be more efficient to use a stripper to remove the Sikkens and then sand?  How much mess does a stripper make?  Do I need to put a tarp on the decorative rocks under/around the deck?]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>FFWINO</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/remove-sikkens-sdr-and-replace-with-twp-100/#post-9842</guid>
