									Redwood home and decks - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/redwood-home-and-decks/</link>
            <lastBuildDate>Mon, 14 Sep 2026 05:28:37 +0000</lastBuildDate>
                        <title>Redwood home and decks</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/redwood-home-and-decks/#post-7498</link>
                        <pubDate>Wed, 30 May 2012 10:28:48 +0000</pubDate>
                        <description><![CDATA[When done with the sanding I would wash the house down with a wood cleaner and a wood brightener. This will help the wood and and the stain.
	If you are in the four counties of LA then y...]]></description>
                        <content:encoded><![CDATA[When done with the sanding I would wash the house down with a wood cleaner and a wood brightener. This will help the wood and and the stain.<br />
	If you are in the four counties of LA then you will not be able to get a quality stain. Outside of that area and I would look at Armstrong Clark or TWP 1500 Series.<br />
	TWP is a registered wood preservative for mildew prevention.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/redwood-home-and-decks/#post-7498</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/redwood-home-and-decks/#post-7496</link>
                        <pubDate>Tue, 29 May 2012 16:20:38 +0000</pubDate>
                        <description><![CDATA[Hello,
	I am in the process of stripping the old solid color stain from my 1940&#039;s home, and refinish the redwood decks.  I found that the whole house is old growth vertical grain clear r...]]></description>
	I am in the process of stripping the old solid color stain from my 1940's home, and refinish the redwood decks.  I found that the whole house is old growth vertical grain clear redwood.  I don't want to use a solid stain again.  I am open to a transparent stain/sealer, and the continuous maintenance issues that come with it.  I have a couple of questions for the board to assist me in achieving my desired end result.  I am 1/4 of the wy around the house with the sanding so I have some time to decide.<br />
	-I have power washed with low pressure,no chemicals, to remove most of the failing finish, sanding to remove the rest.  Do I need to wash down everything again with a brightener, or other chemicals, to remove sawdust and balance the PH, unseen spores, or any other reason?<br />
	-I want a non film forming sealant, for the ease of future maintenance.   I am in southern California.  Are any of the California compliant products going to achieve this.<br />
	-Mildew,  My house is in an shaded oak tree grove on a north facing slope.  I have mildew stains on the concrete hardscape.  Are there any products that fit the above and resist mildew?<br />
	Thanks,<br />
	SteveO90290<br />
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>SteveO90290</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/redwood-home-and-decks/#post-7496</guid>
