									Re-staining an older deck - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/</link>
            <lastBuildDate>Sat, 29 Aug 2026 22:02:40 +0000</lastBuildDate>
                        <title>RE: Re-staining an older deck</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11970</link>
                        <pubDate>Mon, 09 Jul 2018 10:46:12 +0000</pubDate>
                        <description><![CDATA[Just use the same otherwise it will not blend or match.]]></description>
                        <content:encoded><![CDATA[<p>Just use the same otherwise it will not blend or match.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11970</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11966</link>
                        <pubDate>Sun, 08 Jul 2018 16:54:04 +0000</pubDate>
                        <description><![CDATA[Well...we already purchased a gallon of the water base clear and used most of it and then, I believe, I read that oil base is more durable on the floor and steps.  That is why I was asking?]]></description>
                        <content:encoded><![CDATA[<p>Well...we already purchased a gallon of the water base clear and used most of it and then, I believe, I read that oil base is more durable on the floor and steps.  That is why I was asking?</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>Stadig</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11966</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11965</link>
                        <pubDate>Sun, 08 Jul 2018 12:05:11 +0000</pubDate>
                        <description><![CDATA[Why would you do that? Just use the same for all. Much easier.]]></description>
                        <content:encoded><![CDATA[<p>Why would you do that? Just use the same for all. Much easier.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11965</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11961</link>
                        <pubDate>Sat, 07 Jul 2018 14:37:16 +0000</pubDate>
                        <description><![CDATA[We are using Flood.  Is it all right to us a water base (clear) on spindles and oil on the floor and top of banisters?]]></description>
                        <content:encoded><![CDATA[<p>We are using Flood.  Is it all right to us a water base (clear) on spindles and oil on the floor and top of banisters?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11961</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11955</link>
                        <pubDate>Tue, 03 Jul 2018 12:27:40 +0000</pubDate>
                        <description><![CDATA[And clean and brighten after the sanding.]]></description>
                        <content:encoded><![CDATA[<p>And clean and brighten after the sanding.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11955</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11950</link>
                        <pubDate>Mon, 02 Jul 2018 23:47:38 +0000</pubDate>
                        <description><![CDATA[Thanks for the advice.  How does this sound;  Prressure wash; strip;  sand]]></description>
                        <content:encoded><![CDATA[<p>Thanks for the advice.  How does this sound;  Prressure wash; strip;  sand </p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>wkirk</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11950</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11926</link>
                        <pubDate>Fri, 29 Jun 2018 17:35:57 +0000</pubDate>
                        <description><![CDATA[You can not strip a solid stain. Best to sand this off to remove fully. Once done, clean and brighten for the final prep and then stain with a stain like the Restore A Deck Wood Stains]]></description>
                        <content:encoded><![CDATA[<p>You can not strip a solid stain. Best to sand this off to remove fully. Once done, clean and brighten for the final prep and then stain with a stain like the Restore A Deck Wood Stains</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11926</guid>
                        <title>Re-staining an older deck</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11925</link>
                        <pubDate>Fri, 29 Jun 2018 16:33:34 +0000</pubDate>
                        <description><![CDATA[Deck Location State: up state nyFull Sun, Partial Shade, Full Shade: Full Sun : Pressure treated( southern yellow pine i think)Mold or Mildew Issues: NoThe reason for Previous Stain Failure:...]]></description>
                        <content:encoded><![CDATA[<ol><li>Deck Location State: <strong>up state ny</strong></li><li>Full Sun, Partial Shade, Full Shade: <strong>Full Sun </strong>: <strong>Pressure treated( southern yellow pine i think)</strong></li><li>Mold or Mildew Issues: <strong>No</strong></li><li>The reason for Previous Stain Failure: solid stain is peeling badly ; less than 2 years<strong><br /></strong></li><li>Previous Coating? If so brand name and type of stain (Transparent, Semi-transparent, Semi-solid, Solid Stain): <strong>solid stain latex from Ace hardware. not sure of brand</strong></li><li>I want to strip; power wash to get it to bare wood; and use a semi transparent stain..  What would you recommend.  Will the restore a deck wood stain work for this application?  </li></ol>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-staining-an-older-deck/#post-11925</guid>
