									re-stain deck - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-stain-deck/</link>
            <lastBuildDate>Fri, 23 Oct 2026 10:34:19 +0000</lastBuildDate>
                        <title>RE: re-stain deck</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-stain-deck/#post-11975</link>
                        <pubDate>Tue, 10 Jul 2018 03:49:45 +0000</pubDate>
                        <description><![CDATA[Great, thank you!]]></description>
                        <content:encoded><![CDATA[<p>Great, thank you!</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>agjones</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-stain-deck/#post-11975</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-stain-deck/#post-11971</link>
                        <pubDate>Mon, 09 Jul 2018 10:48:33 +0000</pubDate>
                        <description><![CDATA[it is peeling as the Cabot is a filming stain that does not soak in but dried on top of the wood. It will need to be removed and a stripper will probably not work. Best to sand it all off an...]]></description>
                        <content:encoded><![CDATA[<p>it is peeling as the Cabot is a filming stain that does not soak in but dried on top of the wood. It will need to be removed and a stripper will probably not work. Best to sand it all off and then clean and brighten for the final prep. Use a true penetrating stain next time so you do not have to sand again.</p><p>https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-stain-deck/#post-11971</guid>
                        <title>re-stain deck</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-stain-deck/#post-11969</link>
                        <pubDate>Mon, 09 Jul 2018 04:06:25 +0000</pubDate>
                        <description><![CDATA[Hi, I have a cedar deck that was stained last summer with Cabot semi solid stain after we had sanded the entire deck.  The stain is coming off, probably because we didn&#039;t use a brightener or...]]></description>
                        <content:encoded><![CDATA[<p>Hi, I have a cedar deck that was stained last summer with Cabot semi solid stain after we had sanded the entire deck.  The stain is coming off, probably because we didn't use a brightener or cleaner.  Much of the deck still has all of the stain intact.  At this point do you recommend stripping or sanding or both?  Thanks</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-stain-deck/#post-11969</guid>
