									Re-Applying Stain After A Year (Plus Lattice) - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-applying-stain-after-a-year-plus-lattice/</link>
            <lastBuildDate>Thu, 17 Sep 2026 02:44:16 +0000</lastBuildDate>
                        <title>Re-Applying Stain After A Year (Plus Lattice)</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-applying-stain-after-a-year-plus-lattice/#post-8163</link>
                        <pubDate>Fri, 29 Mar 2013 15:56:32 +0000</pubDate>
                        <description><![CDATA[Thank you for the help!
	I looked into the shelf life a little further and it seems that an unopened container is 18 months while an opened container is about 12 months (assuming it&#039;s re...]]></description>
                        <content:encoded><![CDATA[Thank you for the help!<br />
	I looked into the shelf life a little further and it seems that an unopened container is 18 months while an opened container is about 12 months (assuming it's re-sealed well).]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>DeckHelpForEvan</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-applying-stain-after-a-year-plus-lattice/#post-8163</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-applying-stain-after-a-year-plus-lattice/#post-8154</link>
                        <pubDate>Thu, 21 Mar 2013 22:43:38 +0000</pubDate>
                        <description><![CDATA[1. I would lightly clean and then apply a light &quot;maintenance&quot; coat of the Extreme.
	2. Spray the lattice with a pump sprayer and use a brush to wipe or catch any drips.
	3. Not sure ...]]></description>
                        <content:encoded><![CDATA[1. I would lightly clean and then apply a light "maintenance" coat of the Extreme.<br />
	2. Spray the lattice with a pump sprayer and use a brush to wipe or catch any drips.<br />
	3. Not sure on the shelf life of the opened stain. I would ask the manufacturer about that.<br />]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-applying-stain-after-a-year-plus-lattice/#post-8154</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-applying-stain-after-a-year-plus-lattice/#post-8153</link>
                        <pubDate>Wed, 20 Mar 2013 21:09:29 +0000</pubDate>
                        <description><![CDATA[Last year in July I followed the advice I found on this site to clean and stain my deck. I used Restore-a-Deck cleaner/brightener with Defy Extreme stain and it worked quite well for the mos...]]></description>
                        <content:encoded><![CDATA[Last year in July I followed the advice I found on this site to clean and stain my deck. I used Restore-a-Deck cleaner/brightener with Defy Extreme stain and it worked quite well for the most part.<br />
	I have a 400 sq-ft PT Pine deck in full sun. I bought a 5-gallon container of Defy Extreme and it was just barely enough to cover the deck and stairs (mostly). I never ended up getting to some of the side panels and the lattice.<br />
	I have a few questions about what to do now:<br />
	1. Since my deck needed the stain so badly, I needed to use <em>a lot</em> of stain and as I mentioned I didn't have quite enough to go around. This also led to me being a bit stingy with parts of deck flooring. I believe I may not have put quite enough on in general (it's more noticeable in a few spots). Some parts of railings bead rain water, but on some parts of the deck it still soaks in. I did do 2 coats wet-on-wet, but I was moving rather quickly and realized in process that I was going to run out of stain since I did the floor/stairs last.<br />
	Can I re-apply more stain on the deck floor almost a year later in order to improve the coverage/protection or to touch up spots that may look a little uneven? If not, do I need to fully clean/brighten again to re-apply, or can I do a very basic clean to prepare the wood? My deck has no apparent mold/mildew issues and is generally clean.<br />
	2. What's the best way to do the lattice? I have a lot of lattice around my deck, some sections with doors built in to access underneath.  Should I clean/brighten the lattice and apply the stain by hand? This would be extremely tedious and time-consuming, but I'd like to match the lattice with the deck and protect it if possible.<br />
	I've seen aerosol can stain sprayers that looked convenient. Are there any other alternatives besides replacing with new lattice? It's in fairly good condition, but just quite faded and grey.<br />
	Also, I'm trying to decide if I should buy another 5-gallon container of Defy Extreme so I can be sure I have enough. If I can re-apply or touch up every year or 2 I would definitely buy a 5-gallon. Once the container is opened, will it last a long time as long as I keep it sealed?<br />
	I apologize for the wall of text, but hopefully someone can help me!<br />
	TL;DR - can I re-apply Defy Extreme stain nearly a year later in order to improve coverage or touch up sections? Also, what's the best way to do lattice?<br />
	Thanks,<br />
	Evan]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/re-applying-stain-after-a-year-plus-lattice/#post-8153</guid>
