									Prep and stain choice question - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/prep-and-stain-choice-question/</link>
            <lastBuildDate>Sun, 11 Oct 2026 23:48:06 +0000</lastBuildDate>
                        <title>Prep and stain choice question</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/prep-and-stain-choice-question/#post-8627</link>
                        <pubDate>Sat, 03 Aug 2013 12:12:03 +0000</pubDate>
                        <description><![CDATA[Replace the wood than let is weather until Spring. It should be okay. It you are really worried about the Winter than try a light coat of the TimberOil brand this Fall. You will most likely ...]]></description>
                        <content:encoded><![CDATA[Replace the wood than let is weather until Spring. It should be okay. It you are really worried about the Winter than try a light coat of the TimberOil brand this Fall. You will most likely need to apply another coat next season.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/prep-and-stain-choice-question/#post-8627</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/prep-and-stain-choice-question/#post-8626</link>
                        <pubDate>Sat, 03 Aug 2013 00:29:05 +0000</pubDate>
                        <description><![CDATA[I went back and worked on this area and some others and found they are in worse shape than I thought. I understand that new pressure treated lumber needs up to a year before you apply stain ...]]></description>
                        <content:encoded><![CDATA[I went back and worked on this area and some others and found they are in worse shape than I thought. I understand that new pressure treated lumber needs up to a year before you apply stain to it. If that's the case do you simply replace boards now and then stain it next summer? I just worry about the snow and ice on it in the winter without a stain on it. Sorry if I've strayed off the forum topic .<br />
	Thanks for any suggestions you can offer.]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>Grimmiles</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/prep-and-stain-choice-question/#post-8626</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/prep-and-stain-choice-question/#post-8623</link>
                        <pubDate>Fri, 02 Aug 2013 11:02:28 +0000</pubDate>
                        <description><![CDATA[Wood fillers do not work on outside decking very well. AC and TWP do not come in a solid color stains. If you want a solid color stain then try filling the spots first with caulk and level.]]></description>
                        <content:encoded><![CDATA[Wood fillers do not work on outside decking very well. AC and TWP do not come in a solid color stains. If you want a solid color stain then try filling the spots first with caulk and level.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/prep-and-stain-choice-question/#post-8623</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/prep-and-stain-choice-question/#post-8620</link>
                        <pubDate>Fri, 02 Aug 2013 00:04:12 +0000</pubDate>
                        <description><![CDATA[I live up in the Rockies of Colorado at about 8,500&#039;. I&#039;m working on a porch with an added on deck. The porch had been painted and the addon deck stained. I&#039;ve been sanding the paint of the ...]]></description>
                        <content:encoded><![CDATA[I live up in the Rockies of Colorado at about 8,500'. I'm working on a porch with an added on deck. The porch had been painted and the addon deck stained. I've been sanding the paint of the porch and found some pockets in the wood that looked like they used to contain sap but are now empty. They had been painted over. I've cleaned them out and they (2) are about 1/2"x2 1/2-3". They are about 1/4" deep. I wanted to fill them but wasn't sure if a wood filler or something else would be better given I will need to stain the deck after the repair. Is there a a particular product that would be best for this? Also, would a solid stain like Armstrong-Clark or something like TWP 100 look better?<br />
	Thanks!]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/prep-and-stain-choice-question/#post-8620</guid>
