									Playhouse finishing - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/playhouse-finishing/</link>
            <lastBuildDate>Fri, 16 Oct 2026 21:04:25 +0000</lastBuildDate>
                        <title>Playhouse finishing</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/playhouse-finishing/#post-8125</link>
                        <pubDate>Tue, 26 Feb 2013 12:44:32 +0000</pubDate>
                        <description><![CDATA[Nothing lasts 5-7 years. Solids stains will not fade in color like a semi-transparent but they are prone to peeling as they film on top of the wood instead of penetrating into the wood.
...]]></description>
                        <content:encoded><![CDATA[Nothing lasts 5-7 years. Solids stains will not fade in color like a semi-transparent but they are prone to peeling as they film on top of the wood instead of penetrating into the wood.<br />
	Thompson water seal does nothing and it cannot be put on top of another stain. That is poor advice from the company.<br />
	If it beaded water for 10 minutes then yes it could hinder a stain's ability to adhere on top. I would still leave it alone this year. Next year a good cleaning should be enough prep to apply the solid stain.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/playhouse-finishing/#post-8125</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/playhouse-finishing/#post-8124</link>
                        <pubDate>Mon, 25 Feb 2013 15:35:36 +0000</pubDate>
                        <description><![CDATA[Quote from administrator on February 25, 2013, 11:12
	Are you sure you want a solid stain? Solids stains look like paints. If that is what you want then you do not need to strip, just clean...]]></description>
                        <content:encoded><![CDATA[<blockquote><strong>Quote from administrator on February 25, 2013, 11:12</strong><br />
	Are you sure you want a solid stain? Solids stains look like paints. If that is what you want then you do not need to strip, just clean and coat over top.<br />
	I would not use Olympic product. Flood makes a better solid stain and so does Cabot.<br />
	If it was me I would leave it alone for a couple of years then do the maintenance on it. The factory finish will hold up.</blockquote>
	And when you say maintenance on it, what are you referring to?  What the company recommends and putting a Thompson's water sealer on it?  Or you mean clean and recoat with a semi transparent stain?<br />
	The reason I was going for solid stain was because of the longer life of the product.  I was hoping that I could do this one time and get 5-7 years out of it with extremely minimal upkeep and then at that point we would be done with it since the kids would have outgrown it.  <br />
	Also, everything I read says that if there is still a water protection layer (10 minute water test I mentioned) then you can't just use a stain over the top since the stain won't penetrate.  Are you saying the cleaning (I'm assuming with a deck cleaner/brightener?) would be enough to get rid of that coating?<br />
	Thanks again for all the help.]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>playhousequandry</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/playhouse-finishing/#post-8124</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/playhouse-finishing/#post-8123</link>
                        <pubDate>Mon, 25 Feb 2013 11:12:34 +0000</pubDate>
                        <description><![CDATA[Are you sure you want a solid stain? Solids stains look like paints. If that is what you want then you do not need to strip, just clean and coat over top.
	I would not use Olympic produc...]]></description>
                        <content:encoded><![CDATA[Are you sure you want a solid stain? Solids stains look like paints. If that is what you want then you do not need to strip, just clean and coat over top.<br />
	If it was me I would leave it alone for a couple of years then do the maintenance on it. The factory finish will hold up.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/playhouse-finishing/#post-8123</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/playhouse-finishing/#post-8121</link>
                        <pubDate>Sun, 24 Feb 2013 16:29:33 +0000</pubDate>
                        <description><![CDATA[Question about finishing a playhouse for the kids.  We bought one of these from Costco for the backyard:
	It comes from the factory with a water based stain/sealant on it, and the ma...]]></description>
                        <content:encoded><![CDATA[Question about finishing a playhouse for the kids.  We bought one of these from Costco for the backyard:<br />
	http://www.costco.com/Cedar-Summit&#37;E2&#37;84&#37;A2-Cedarview-Resort-Premium-Playset.product.100019555.html?catalogId=10701&keyword=cedar+summit&langId=-1&storeId=10301<br />
	It comes from the factory with a water based stain/sealant on it, and the manufacturer recommends using a water based sealer on it each year (Thompson's).  I know Thompson's is thought to be a horrible product, so I wanted to use a better stain/sealant on it before we build it. <br />
	I was wondering if anyone had experience with the Olympic Maximum SOLID stains (http://www.olympic.com/products/stains/12/olympic-maximum-stain-sealant-in-one).  This will be in a hot summer / wet and cold winter location (NW).  <br />
	To do this, I would have to remove the existing coating, and I was thinking of using the Olympic premium stain stripper (http://www.olympic.com/products/stains/29/olympic-premium-stain-stripper).  Does anyone have experience with that?  I did a water test with the factory coating, and after 10 minutes most of the water was still puddled, but there was some discoloration of the wood, so I have serious doubts about the longevity of the factory finish.<br />
	Thanks!]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/playhouse-finishing/#post-8121</guid>
