									Play Set Staining Help - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/play-set-staining-help/</link>
            <lastBuildDate>Sat, 26 Sep 2026 14:08:47 +0000</lastBuildDate>
                        <title>RE: Play Set Staining Help</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/play-set-staining-help/#post-15044</link>
                        <pubDate>Mon, 27 Jul 2026 12:35:38 +0000</pubDate>
                        <description><![CDATA[Most of the old stain is gone, so no need to strip. Clean and brighten for prep while pressure washing:
For the stain, look at the Armstrong Clark, TWP 1500 Series, or the Restore-A-Deck se...]]></description>
                        <content:encoded><![CDATA[<p>Most of the old stain is gone, so no need to strip. Clean and brighten for prep while pressure washing:</p>
<p>https://www.deckstainhelp.com/product/restore-a-deck-package-300/</p>
<p>For the stain, look at the Armstrong Clark, TWP 1500 Series, or the Restore-A-Deck semi-transparent.</p>
<p>https://www.deckstainhelp.com/best-semi-transparent-deck-stain-reviews/</p>
<p>Use stain pads or brushes to apply.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/play-set-staining-help/#post-15044</guid>
                        <title>Play Set Staining Help</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/play-set-staining-help/#post-15043</link>
                        <pubDate>Sun, 26 Jul 2026 20:06:22 +0000</pubDate>
                        <description><![CDATA[Hello, I have a play set that I built using reclaimed barn wood that needs a new coat of stain. Also, around the playset I have a border that I used treated rough sawn southern yellow pine 5...]]></description>
                        <content:encoded><![CDATA[<p>Hello, I have a play set that I built using reclaimed barn wood that needs a new coat of stain. Also, around the playset I have a border that I used treated rough sawn southern yellow pine 5x5's for, these should be plenty ready for a first coat of stain as well.</p>
<p>A. The previous stain was applied 2 years ago (barn wood only), about when the wood started seeing daylight.                  Before that the wood was inside a barn built in the 1890's.</p>
<p>B. Most of the wood is rough and not sanded, this includes some decay and bug damage. </p>
<p>C. I assume the old stain needs stripped and I should use a wood cleaner or brightener? I would like to remove the UV damage to bring back some color, such as using the Armstrong Clark.</p>
<p>D. Best application method? Brush, pump sprayer, airless sprayer?</p>
1925
1920
1922
1924
1923
1921
<p>&nbsp;</p>
<ul>
<li>1. Indiana</li>
</ul>
<ul>
<li>2. Full Sun</li>
</ul>
<ul>
<li>3. Unsure, whichever hardwoods were cut down nearby to build the barn</li>
</ul>
<ul>
<li>4. North side, which is the rock wall seems to be the only area with mold/mildew</li>
</ul>
<ul>
<li>5. Previously used Sherwin Williams super deck oil based transparent stain (6511-52639). While it looked great at first it did not provide protection for much longer than 6-12 months and weathering/discoloring started to appear, so now a lot of the wood looks gray/white.</li>
</ul>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>shorkj01</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/play-set-staining-help/#post-15043</guid>
