									Part new/Part old deck stain - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/part-newpart-old-deck-stain/</link>
            <lastBuildDate>Sat, 19 Sep 2026 11:03:22 +0000</lastBuildDate>
                        <title>Part new/Part old deck stain</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/part-newpart-old-deck-stain/#post-9798</link>
                        <pubDate>Mon, 02 Feb 2015 13:51:29 +0000</pubDate>
                        <description><![CDATA[Do you have any recommendations of products to use for stripping and brightening the old wood? Also, what brand of stain for a semi-solid stain would you recommend?]]></description>
                        <content:encoded><![CDATA[Do you have any recommendations of products to use for stripping and brightening the old wood? Also, what brand of stain for a semi-solid stain would you recommend?]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>Anonymous</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/part-newpart-old-deck-stain/#post-9798</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/part-newpart-old-deck-stain/#post-9789</link>
                        <pubDate>Fri, 30 Jan 2015 16:40:35 +0000</pubDate>
                        <description><![CDATA[You should strip odd the old stain first and brighten the wood. Once removed you can look at a semi-solid or solid (opaque) stain so it blends between the new and old wood. Please read this ...]]></description>
                        <content:encoded><![CDATA[You should strip odd the old stain first and brighten the wood. Once removed you can look at a semi-solid or solid (opaque) stain so it blends between the new and old wood. Please read this about the new section:<br />
	http://www.deckstainhelp.com/staining-a-new-deck/]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/part-newpart-old-deck-stain/#post-9789</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/part-newpart-old-deck-stain/#post-9788</link>
                        <pubDate>Thu, 29 Jan 2015 14:55:51 +0000</pubDate>
                        <description><![CDATA[The sun and moisture exposed areas of our deck were rotted, so we decided to replace 3/4 of the deck with new pressure-treated pine, while leaving 1/4 of the deck (covered and unrotted) in t...]]></description>
                        <content:encoded><![CDATA[The sun and moisture exposed areas of our deck were rotted, so we decided to replace 3/4 of the deck with new pressure-treated pine, while leaving 1/4 of the deck (covered and unrotted) in the old wood. We will also be replacing all of the railing.<br />
	The old wood remaining on 1/4 of the deck is aged and obviously darker than the new pine (as seen in the attached photo). <br />
	What stain would you recommend to create as much uniformity as possible between the old and new deck? Would I need to use a more opaque stain? Any recommendation would be helpful, as there are so many options.<br />
	Thank you in advance!<br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2015/01/7g8sq-Deck.jpg" alt="" />]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>snlangford</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/part-newpart-old-deck-stain/#post-9788</guid>
