									Newbie - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/</link>
            <lastBuildDate>Sun, 18 Oct 2026 17:20:39 +0000</lastBuildDate>
                        <title>RE: Newbie</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12517</link>
                        <pubDate>Sat, 04 May 2019 11:37:22 +0000</pubDate>
                        <description><![CDATA[I would test an area with another coat and see if it dries okay and looks correctly. If all good after 24-48 hours, then recoat the rest. If not, you will need to strip and start over.You do...]]></description>
                        <content:encoded><![CDATA[<p>I would test an area with another coat and see if it dries okay and looks correctly. If all good after 24-48 hours, then recoat the rest. If not, you will need to strip and start over.</p><p>You do not need to prep anything for the recoat test.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12517</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12509</link>
                        <pubDate>Sat, 04 May 2019 01:24:09 +0000</pubDate>
                        <description><![CDATA[This is an area that got most rain.]]></description>
                        <content:encoded><![CDATA[<p>This is an area that got most rain.</p><p> </p><p>652,651</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>kevtorf</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12509</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12508</link>
                        <pubDate>Sat, 04 May 2019 01:22:25 +0000</pubDate>
                        <description><![CDATA[This is an area that did not get much rain.]]></description>
                        <content:encoded><![CDATA[<p>This is an area that did not get much rain.</p><p> </p><p>650</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12508</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12507</link>
                        <pubDate>Fri, 03 May 2019 21:10:53 +0000</pubDate>
                        <description><![CDATA[After 5 months, I eventually got around to staining my deck. I did what you recommended, thanks. I removed the stain, I used the brighter, I waited 4 days and stained the deck. It looked gre...]]></description>
                        <content:encoded><![CDATA[<p>After 5 months, I eventually got around to staining my deck. I did what you recommended, thanks. I removed the stain, I used the brighter, I waited 4 days and stained the deck. It looked great. Thanks again.</p><p>Unfortunately after staining the deck, about 8 hours later we had some unplanned rain. It was not heavy but the deck got totally wet for about 4 hours and then 12 hours later it rained again.</p><p>Bottom line in areas of the deck the rain did not soak the deck still looks great, rich mangaris red with a tint of brown from the amber stain. The other areas of the deck look spotty and are a dull yellow as if it did not get stained. </p><p>My Question. Do I need to start again with the whole process or can I just re-stain the wood as if I am doing a second coat. I stained it 1 week ago. </p><p>Thanks again for all your help.</p><p>Kevin</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12507</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12293</link>
                        <pubDate>Thu, 01 Nov 2018 09:28:39 +0000</pubDate>
                        <description><![CDATA[You do not need to sand. If using the AC stain, about 4-6 Gallons for the 1 coatNo need to clean if you are stripping. Strip and brighten for the prep.You cannot do this on the same day. Pre...]]></description>
                        <content:encoded><![CDATA[<p>You do not need to sand. </p><p>If using the AC stain, about 4-6 Gallons for the 1 coat</p><p>No need to clean if you are stripping. Strip and brighten for the prep.</p><p>You cannot do this on the same day. Prep one day and stain 48 hours later if the weather cooperates.</p><p>Do not spray the AC. Use a stain pad for the application. This is a penetrating stain so does not get slippery.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12293</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12292</link>
                        <pubDate>Thu, 01 Nov 2018 01:26:37 +0000</pubDate>
                        <description><![CDATA[Thanks for the information. I want to make sure that I don&#039;t need to sand. The painting company that quoted me was going to sand this first! Its great news if I don&#039;t, but want to do it the ...]]></description>
                        <content:encoded><![CDATA[<p>Thanks for the information. I want to make sure that I don't need to sand. The painting company that quoted me was going to sand this first! Its great news if I don't, but want to do it the best way possible. I'm new at this and appreciate the help.</p><p>I have a few more questions:</p><p>My deck is about 1200 sq feet how much stain do I need?</p><p>How many coats do I need of the stain?</p><p>Restore a deck has a cleaner do I need to do this first?</p><p>The stripper and brighter are separate applications, is that correct?</p><p>Can I do this all in a single day? </p><p>Should I spray or brush the product?</p><p>Can I spray the Armstrong Stain?</p><p>This is by a pool so wanted to check on how slippery the final finish will get?</p><p>Thanks again</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12292</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12278</link>
                        <pubDate>Mon, 22 Oct 2018 15:58:32 +0000</pubDate>
                        <description><![CDATA[Use the Armstrong Clark Stain in Amber color. Prep with the Restore A Deck Stain Stripper and Brightener. No need to sand this.Your wood types require an annual recoat. Just clean and reappl...]]></description>
                        <content:encoded><![CDATA[<p>Use the Armstrong Clark Stain in Amber color. Prep with the Restore A Deck Stain Stripper and Brightener. No need to sand this.</p><p>Your wood types require an annual recoat. Just clean and reapply the AC as needed.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12278</guid>
                        <title>Help</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12277</link>
                        <pubDate>Mon, 22 Oct 2018 15:49:40 +0000</pubDate>
                        <description><![CDATA[I have a mangaris wood deck next to a pool. The deck is about two years old and is showing signs of weathering. The original builder sealed the deck three times. The first was a water base t...]]></description>
                        <content:encoded><![CDATA[<p>I have a mangaris wood deck next to a pool. The deck is about two years old and is showing signs of weathering. The original builder sealed the deck three times. The first was a water base that didn’t last long in the sun, 6 months. The second was so slippery when you got out the pool you nearly killed yourself. The last effort worked but hasn’t lasted long 9 months.</p><p>I want to do it myself. I hired a power sander and am looking for the best recommendation. I want to keep as much of the natural wood look as possible, if anything a slight brown to offset the red mangaris. It needs to be non-slip. It gets about 4 months of direct sun light. 3 months of dew. It is not extreme as I am in CA.566,565</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12277</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12267</link>
                        <pubDate>Wed, 17 Oct 2018 20:08:12 +0000</pubDate>
                        <description><![CDATA[You will need a custom solid color stain for a Blue. Try the Flood Pro Series Solid Deck Stains. Just pressure wash for prep. You do not need to strip to apply a solid stain.]]></description>
                        <content:encoded><![CDATA[<p>You will need a custom solid color stain for a Blue. Try the Flood Pro Series Solid Deck Stains. Just pressure wash for prep. You do not need to strip to apply a solid stain.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12267</guid>
                        <title>Newbie</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12266</link>
                        <pubDate>Wed, 17 Oct 2018 17:03:23 +0000</pubDate>
                        <description><![CDATA[I just bought a house, and I have NO IDEA what I am doing...just learning as I go, and not ashamed to admit it, LOL. The previous sellers have a gray roof with a dark brown deck/trim/concret...]]></description>
                        <content:encoded><![CDATA[<p>I just bought a house, and I have NO IDEA what I am doing...just learning as I go, and not ashamed to admit it, LOL. <br /><br />The previous sellers have a gray roof with a dark brown deck/trim/concrete, I am thinking they used a semitransparent stain? Not a clue as to what brand. It doesn't seem splintered, just faded/worn in the high traffic areas. <br /><br />I would like to take it to a dark blue (possibly solid stain? -- unless somebody has a better suggestion.) <br /><br />I am trying to decipher as to I need to "strip" or "clean" the previous stain.<br /><br />Any insight would be greatly appreciated!</p><p> </p><p>I tried to attach the files below.</p><p> </p><p>555,554,553</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>dhisaw23</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/newbie/#post-12266</guid>
