									New Lumber added to deck - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-lumber-added-to-deck/</link>
            <lastBuildDate>Thu, 22 Oct 2026 08:54:10 +0000</lastBuildDate>
                        <title>RE: New Lumber added to deck</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-lumber-added-to-deck/#post-12845</link>
                        <pubDate>Thu, 01 Aug 2019 13:49:41 +0000</pubDate>
                        <description><![CDATA[New wood is more like 3+ months:it is only two boards, just stain them now. You will need to reapply another coat to those two boards next Spring.]]></description>
                        <content:encoded><![CDATA[<p>New wood is more like 3+ months: https://www.deckstainhelp.com/staining-a-new-deck/</p><p>Since it is only two boards, just stain them now. You will need to reapply another coat to those two boards next Spring.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-lumber-added-to-deck/#post-12845</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-lumber-added-to-deck/#post-12844</link>
                        <pubDate>Thu, 01 Aug 2019 13:37:21 +0000</pubDate>
                        <description><![CDATA[In a previous post you mentioned waiting 1-12 months before staining new wood with the aforementioned process.If I need to replace two floor boards now I&#039;m afraid it will be Fall/Winter by t...]]></description>
                        <content:encoded><![CDATA[<p>In a previous post you mentioned waiting 1-12 months before staining new wood with the aforementioned process.</p><p>If I need to replace two floor boards now I'm afraid it will be Fall/Winter by the time it's ready to stain correctly.</p><p> </p><p>Would you say a month is the shortest amount of time you would wait to stain new wood? </p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>DkGrub</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-lumber-added-to-deck/#post-12844</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-lumber-added-to-deck/#post-12839</link>
                        <pubDate>Tue, 30 Jul 2019 11:26:41 +0000</pubDate>
                        <description><![CDATA[Doesn&#039;t matter what the chemical was used to pressure treat the wood, you cannot stain new wood right away as the stain will not soak in correctly and fail. Letting the wood sit outside to n...]]></description>
                        <content:encoded><![CDATA[<p>Doesn't matter what the chemical was used to pressure treat the wood, you cannot stain new wood right away as the stain will not soak in correctly and fail. Letting the wood sit outside to naturally oxidize and weather and then using a deck cleaner and wood brightener to remove the oxidation and mill glaze is the proper way.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-lumber-added-to-deck/#post-12839</guid>
                        <title>New Lumber added to deck</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-lumber-added-to-deck/#post-12838</link>
                        <pubDate>Tue, 30 Jul 2019 01:03:08 +0000</pubDate>
                        <description><![CDATA[My contractor added three support posts to my deck today that was stained three weeks ago with TWP 1500. My contractor commented on how good the deck looks and stated that I could stain the ...]]></description>
                        <content:encoded><![CDATA[<p>My contractor added three support posts to my deck today that was stained three weeks ago with TWP 1500. My contractor commented on how good the deck looks and stated that I could stain the new posts in a few days. He was told at the lumber yard that a new process is being used to treat the pine wood (Severe Weather, ground contact general use 6x6 posts). I did wait one year after the deck was constructed before applying stain. Are you aware of any changes of how the new lumber is treated? And what would you recommend? Thanks</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>BrianKJ</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-lumber-added-to-deck/#post-12838</guid>
