									New Cedar - Immediate Stain Recommendation - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-cedar-immediate-stain-recommendation/</link>
            <lastBuildDate>Fri, 02 Oct 2026 01:32:02 +0000</lastBuildDate>
                        <title>RE: New Cedar - Immediate Stain Recommendation</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-cedar-immediate-stain-recommendation/#post-13264</link>
                        <pubDate>Sun, 10 May 2020 17:54:00 +0000</pubDate>
Copy that ... thanks.]]></description>
                        <content:encoded><![CDATA[<p>@administrator</p><p></p>
Copy that ... thanks.]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>Sanibel</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-cedar-immediate-stain-recommendation/#post-13264</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-cedar-immediate-stain-recommendation/#post-13262</link>
                        <pubDate>Sun, 10 May 2020 13:10:00 +0000</pubDate>
                        <description><![CDATA[It will not take is the issue and will fail in months. You also only need to stain the wood that is exposed. You can do it if you want but you will need to redo within a year or less.]]></description>
                        <content:encoded><![CDATA[<p>It will not take is the issue and will fail in months. You also only need to stain the wood that is exposed. You can do it if you want but you will need to redo within a year or less.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-cedar-immediate-stain-recommendation/#post-13262</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-cedar-immediate-stain-recommendation/#post-13261</link>
                        <pubDate>Sun, 10 May 2020 13:05:19 +0000</pubDate>
                        <description><![CDATA[Understood ... allowing some weathering is best.  I was hoping for some middle ground. 550SF deck, 14 posts, elevation from ground 12&quot;.
Once new 6&quot; cedar posts are re-installed, access to a...]]></description>
                        <content:encoded><![CDATA[Understood ... allowing some weathering is best.  I was hoping for some middle ground. 550SF deck, 14 posts, elevation from ground 12".
Once new 6" cedar posts are re-installed, access to a complete coverage is impossible and protecting the existing composite deck surface a bit of a challenge. Some recommendation even for a single coat?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-cedar-immediate-stain-recommendation/#post-13261</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-cedar-immediate-stain-recommendation/#post-13260</link>
                        <pubDate>Sun, 10 May 2020 12:50:11 +0000</pubDate>
                        <description><![CDATA[You cannot prestain new wood. See here:]]></description>
                        <content:encoded><![CDATA[You cannot prestain new wood. See here: https://www.deckstainhelp.com/staining-a-new-deck/]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-cedar-immediate-stain-recommendation/#post-13260</guid>
                        <title>New Cedar - Immediate Stain Recommendation</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-cedar-immediate-stain-recommendation/#post-13259</link>
                        <pubDate>Sun, 10 May 2020 12:44:55 +0000</pubDate>
                        <description><![CDATA[I am having the cedar posts and railing caps replaced on my current deck. Deck material is composite and in excellent condition (4-yrs old) - understructure all CCA.  I want to apply two coa...]]></description>
                        <content:encoded><![CDATA[I am having the cedar posts and railing caps replaced on my current deck. Deck material is composite and in excellent condition (4-yrs old) - understructure all CCA.  I want to apply two coats of a semi-transparent stain to the new cedar before it is installed.  Which product/manufacturer do you recommend for good penetration, lasting results? Thanks.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/new-cedar-immediate-stain-recommendation/#post-13259</guid>
