									Need advice on what to do next with this deck cleaning / stripping / staining - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-what-to-do-next-with-this-deck-cleaning-stripping-staining/</link>
            <lastBuildDate>Wed, 21 Oct 2026 08:08:24 +0000</lastBuildDate>
                        <title>RE: Need advice on what to do next with this deck cleaning / stripping / staining</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-what-to-do-next-with-this-deck-cleaning-stripping-staining/#post-12843</link>
                        <pubDate>Tue, 30 Jul 2019 16:18:55 +0000</pubDate>
                        <description><![CDATA[Pressure wash off what is loose and then you can stain over the rest. Look at one of these brands:]]></description>
                        <content:encoded><![CDATA[<p>Pressure wash off what is loose and then you can stain over the rest. Look at one of these brands: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-what-to-do-next-with-this-deck-cleaning-stripping-staining/#post-12843</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-what-to-do-next-with-this-deck-cleaning-stripping-staining/#post-12842</link>
                        <pubDate>Tue, 30 Jul 2019 14:41:29 +0000</pubDate>
                        <description><![CDATA[Sir, you are right!  It is Solid and I&#039;m recoating with Solid.  Thank you for the correction. It&#039;s also called SuperDeck, NOT DeckScape. I&#039;ll try to edit original post.  So, can I just recoa...]]></description>
                        <content:encoded><![CDATA[<p>Sir, you are right!  It is Solid and I'm recoating with Solid.  Thank you for the correction. It's also called SuperDeck, NOT DeckScape. I'll try to edit original post.  </p><p>So, can I just recoat or do I need to strip?  </p><p>Thanks. </p><p>https://i.imgur.com/HiUa6kp.jpg</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>RickDel</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-what-to-do-next-with-this-deck-cleaning-stripping-staining/#post-12842</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-what-to-do-next-with-this-deck-cleaning-stripping-staining/#post-12841</link>
                        <pubDate>Tue, 30 Jul 2019 14:29:48 +0000</pubDate>
                        <description><![CDATA[You will not be able to strip this fully as what you have is not semi-transparent but solid color/opaque in appearance. They sold you an incorrect product if it was supposed to be semi-trans...]]></description>
                        <content:encoded><![CDATA[<p>You will not be able to strip this fully as what you have is not semi-transparent but solid color/opaque in appearance. They sold you an incorrect product if it was supposed to be semi-transparent. Your two options are to power sand it all off or recoat it with another solid stain.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-what-to-do-next-with-this-deck-cleaning-stripping-staining/#post-12841</guid>
                        <title>Need advice on what to do next with this deck cleaning / stripping / staining</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-what-to-do-next-with-this-deck-cleaning-stripping-staining/#post-12840</link>
                        <pubDate>Tue, 30 Jul 2019 14:18:24 +0000</pubDate>
                        <description><![CDATA[Hello...  I started a deck restaining project but not sure I&#039;m doing it correctly, and I may actually be causing myself more work.  So, I&#039;ve stopped to get some advice.Two years ago, I strip...]]></description>
                        <content:encoded><![CDATA[<p>Hello...  I started a deck restaining project but not sure I'm doing it correctly, and I may actually be causing myself more work.  So, I've stopped to get some advice.</p><p>Two years ago, I stripped my deck planks by sanding them to bare wood and then stained with semitransparent SW DeckScape.  It looked good, but only two years later I have a few spots chipping / peeling away.  </p><p>Since I restored the boards by sanding last time, I thought I'd just strip it down with chemicals this time and redo, but the stain is not coming off easily.  So, I returned to the web to get some online help and now I think that maybe I didn't need to strip it at all. </p><p>** I thought I needed to strip because I put some tape down on those areas where it was chipping and pulled stain off**  </p><p>I've completed about 1/10th of the deck.  Should I continue stripping or just clean and restain it as is?  </p><p>I intend to recover with DeckScape but a slightly different color (more brown than red).</p><p>Here's what it looks like (this is a pic of the 75% of the deck I haven't applied stripper to). I know I went a little too strong with the pressure washer because it's fusing up (I figured I was going to do a light sanding anyway so I didn't think it mattered). </p><p>https://i.imgur.com/pxP20x1.jpg</p><p>https://i.imgur.com/0PJDIik.jpg</p><p> Here's the 25% I stripped:</p><p>https://i.imgur.com/ZsNo68a.jpg</p><p>https://i.imgur.com/Kx1l4nv.jpg</p><p>https://i.imgur.com/cX82l4l.jpg</p><p>https://i.imgur.com/rZvDH5z.jpg</p><p>I'm using a mixture of Pressure Tek F18 stripper and 10% sodium hypochlorite applied with a pump sprayer.  Let dwell approx 15 - 30 mins and rinse off at approx 1000psi.  I also intend to use F8 Brightener / Neutralizer after my last round of F18.</p><p>QUESTIONS:  </p><p>1. Should I stop stripping, finish cleaning the deck with SH, than only sand the boards I've already stripped and apply stain to the entire deck?</p><p>2. If I continue stripping, do I need to remove ALL the old stain?  I'm reapplying same manufacture product and probably a little darker.  (can I stain over what I've already stripped now, or does more of that old stain need to be removed?)</p><p>3. How concerned do I need to be about getting SH on glass? I don't want to etch my glass doors. I rinsed them before and after, but they're not saying wet long enough to prevent the overspray SH from getting on the glass and drying (hand pumping chemicals takes me a long time). </p><p>4. Lastly, if you guys recommend fully striping. What's the easiest way?  I probably spend 30 hours sanding down those deck boards just two years ago.  I'll swap them out with composite boards before working that hard on them again!  I used a belt sander and orbital sander last time.  I saw a product called Diamabrush that looks fast, but expensive and might not be too durable. </p><p>Any advice is GREATLY appreciated.  Thank you!</p><p> </p><p> </p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-what-to-do-next-with-this-deck-cleaning-stripping-staining/#post-12840</guid>
