									Need advice on re-staining - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-re-staining/</link>
            <lastBuildDate>Fri, 25 Sep 2026 12:42:45 +0000</lastBuildDate>
                        <title>RE: Need advice on re-taining</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-re-staining/#post-11470</link>
                        <pubDate>Mon, 02 Oct 2017 15:00:47 +0000</pubDate>
                        <description><![CDATA[thank you!]]></description>
                        <content:encoded><![CDATA[<p>thank you!</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>gvivanco</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-re-staining/#post-11470</guid>
                        <title>RE: Need advice on re-staining</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-re-staining/#post-11469</link>
                        <pubDate>Mon, 02 Oct 2017 13:38:16 +0000</pubDate>
                        <description><![CDATA[Yes, you need to prep again. Do in the Spring.]]></description>
                        <content:encoded><![CDATA[<p>Yes, you need to prep again. Do in the Spring.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-re-staining/#post-11469</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-re-staining/#post-11467</link>
                        <pubDate>Mon, 02 Oct 2017 12:49:31 +0000</pubDate>
                        <description><![CDATA[Also, I forgot to ask if I should do it now in the Fall or wait until spring?]]></description>
                        <content:encoded><![CDATA[<p>Also, I forgot to ask if I should do it now in the Fall or wait until spring? </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-re-staining/#post-11467</guid>
                        <title>Need advice on re-staining</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-re-staining/#post-11466</link>
                        <pubDate>Mon, 02 Oct 2017 12:45:43 +0000</pubDate>
                        <description><![CDATA[Hi, I’m in Georgia, my deck is in full sun, and it’s pressure treated pine. The deck was built in 2014, left to weather for 12 months, and then cleaned with the restore-a-deck system (cleane...]]></description>
                        <content:encoded><![CDATA[<p>Hi, I’m in Georgia, my deck is in full sun, and it’s pressure treated pine. The deck was built in 2014, left to weather for 12 months, and then cleaned with the restore-a-deck system (cleaner and brightener), and then stained with 1 coat of Armstrong Clark semi transparent. After the application of the stain, I had many areas of the deck where there were beads of some sticky substance coming up from the wood. I thought it was weird (I didn’t read anything about that happening during my research on your site before I did it), but I didn’t do anything about it. Anyway, AC recommended a second coat of the stain on the horizontal surfaces in 12 months. My question is - do I do the restore a deck system again before I add more stain? And do you know what the sticky beading was and can I avoid that this time? </p><p>Thank you so much!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/need-advice-on-re-staining/#post-11466</guid>
