									Log home siding redo - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/</link>
            <lastBuildDate>Wed, 16 Sep 2026 22:29:24 +0000</lastBuildDate>
                        <title>Log home siding redo</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-10078</link>
                        <pubDate>Fri, 05 Jun 2015 11:13:58 +0000</pubDate>
                        <description><![CDATA[It may streak it. Hennishly though this whole side should take less then 30-60 minutes to clean and brighten when using a pressure washer. Key is to move fast and keep a wet surface. We woul...]]></description>
                        <content:encoded><![CDATA[It may streak it. Hennishly though this whole side should take less then 30-60 minutes to clean and brighten when using a pressure washer. Key is to move fast and keep a wet surface. We would apply the cleaner to the entire side of the house, pressure wash all, rinse, then brighten all.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-10078</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-10075</link>
                        <pubDate>Thu, 04 Jun 2015 15:17:21 +0000</pubDate>
                        <description><![CDATA[Good morning. 
	I am setting up to clean a gable end. 
	I need to know if I have to drape the 
	wood under the platform of the scaffold? 
	I am worrying about the cleaner dripping 
	on ...]]></description>
                        <content:encoded><![CDATA[Good morning. <br />
	I am setting up to clean a gable end. <br />
	I need to know if I have to drape the <br />
	wood under the platform of the scaffold? <br />
	I am worrying about the cleaner dripping <br />
	on the lower wood and streaking it or not <br />
	being able to clean it properly when I get to it. <br />
	I will be working from top down. <br />
	Thanks for the help <br />
	Greg <br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2015/06/8hrz7-SAM_3286.JPG" alt="" />]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>gregt</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-10075</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9904</link>
                        <pubDate>Sun, 26 Apr 2015 14:05:36 +0000</pubDate>
                        <description><![CDATA[The cleaner is not a stripper but since it has been 6 years, it should remove it.]]></description>
                        <content:encoded><![CDATA[The cleaner is not a stripper but since it has been 6 years, it should remove it.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9904</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9903</link>
                        <pubDate>Sun, 26 Apr 2015 00:35:48 +0000</pubDate>
                        <description><![CDATA[Thanks for all your help. 
	I did a sample today. 
	Here are the before and after pics.
	The question I have now is, In the first post I mentioned that the 
	siding was treated with T...]]></description>
                        <content:encoded><![CDATA[Thanks for all your help. <br />
	I did a sample today. <br />
	Here are the before and after pics.<br />
	The question I have now is, In the first post I mentioned that the <br />
	siding was treated with Thompsons Water Seal. <br />
	Will the cleaner take that off and get to the wood underneath? <br />
	Look forward to this project. <br />
	The 2x6 was Doug Fir, I just wanted some perspective. <br />
	Greg <br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2015/04/6145x-Before-.JPG" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2015/04/gnw6p-After.JPG" alt="" />]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9903</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9900</link>
                        <pubDate>Sat, 25 Apr 2015 10:59:47 +0000</pubDate>
                        <description><![CDATA[The cleaner is only active for a hour or two. The brightener stays active indefinitely. Make sure you mix the cleaner in a separate container then transfer to a pump prayer for application. ...]]></description>
                        <content:encoded><![CDATA[The cleaner is only active for a hour or two. The brightener stays active indefinitely. Make sure you mix the cleaner in a separate container then transfer to a pump prayer for application. It does not dissolve 100&#37; and you want to to careful that you do not clog your sprayer tip. Apply the cleaner and pressure wash off making sure that you wash with the grain of the wood. Concentrate on removing the oxidized/gray wood cells and the black mold. Do in sections of 100-200 sq. feet at a time.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9900</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9899</link>
                        <pubDate>Sat, 25 Apr 2015 00:03:57 +0000</pubDate>
                        <description><![CDATA[I received your RAD kit. 
	I want to play with it before the real deal. 
	If I mix up some of it, is there a pot life of the chemical? 
	Or should I just mix what I want to use for my tri...]]></description>
                        <content:encoded><![CDATA[I received your RAD kit. <br />
	I want to play with it before the real deal. <br />
	If I mix up some of it, is there a pot life of the chemical? <br />
	Or should I just mix what I want to use for my trial? <br />
	Greg]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9899</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9881</link>
                        <pubDate>Thu, 16 Apr 2015 10:23:19 +0000</pubDate>
                        <description><![CDATA[No idea. Check with manufacturers.]]></description>
                        <content:encoded><![CDATA[No idea. Check with manufacturers.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9881</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9879</link>
                        <pubDate>Thu, 16 Apr 2015 00:24:07 +0000</pubDate>
                        <description><![CDATA[Thanks so much for your input. 
	I will get on it 
	Is there a dealer near me? 
	I live by Prescott AZ.  
	Greg]]></description>
                        <content:encoded><![CDATA[Thanks so much for your input. <br />
	I will get on it <br />
	Is there a dealer near me? <br />
	I live by Prescott AZ.  <br />
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9879</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9877</link>
                        <pubDate>Wed, 15 Apr 2015 17:35:02 +0000</pubDate>
                        <description><![CDATA[Prep with the Restore A Deck Kits and pressure washing. Stain with TWP in the Honeytone. It will look great!]]></description>
                        <content:encoded><![CDATA[Prep with the Restore A Deck Kits and pressure washing. Stain with TWP in the Honeytone. It will look great!]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9877</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9876</link>
                        <pubDate>Wed, 15 Apr 2015 00:42:33 +0000</pubDate>
                        <description><![CDATA[I have a 6 year old home that I built myself. 
	It has half round southern pine siding. 
	It was initially just coated with Thompsons Waterseal 
	As you can see it is a bit of a mess. 
                        <content:encoded><![CDATA[I have a 6 year old home that I built myself. <br />
	It has half round southern pine siding. <br />
	It was initially just coated with Thompsons Waterseal <br />
	As you can see it is a bit of a mess. <br />
	What would you recommend to even out the colors <br />
	and get me to a warm honey color. <br />
	Thanks in advance for your help in this<br />
	Greg  <br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2015/04/03ir4-SAM_3117.JPG" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2015/04/7yf29-SAM_3118.JPG" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2015/04/l1ppi-SAM_3119.JPG" alt="" />]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/log-home-siding-redo/#post-9876</guid>
