									I messed up, I think. - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/</link>
            <lastBuildDate>Tue, 27 Oct 2026 11:04:29 +0000</lastBuildDate>
                        <title>I messed up, I think.</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10311</link>
                        <pubDate>Sat, 15 Aug 2015 12:58:07 +0000</pubDate>
                        <description><![CDATA[Quote from wooddeck1 on August 14, 13:13
	Thanks. Live in Chicago so that may be an issue. If it peels over the winter and into Spring will I need to strip off everything and start over? Ye...]]></description>
                        <content:encoded><![CDATA[<blockquote><strong>Quote from wooddeck1 on August 14, 13:13</strong><br />
	Thanks. Live in Chicago so that may be an issue. If it peels over the winter and into Spring will I need to strip off everything and start over? </blockquote>Yes you will. Also use a penetrating stain next Spring.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10311</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10308</link>
                        <pubDate>Fri, 14 Aug 2015 20:01:34 +0000</pubDate>
	The absolute best way to insure that your deck will be properly cared for is to start from scratch. strip neutralize and restain you cant go wrong.<br />]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>stevenm</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10308</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10306</link>
                        <pubDate>Fri, 14 Aug 2015 13:13:49 +0000</pubDate>
                        <description><![CDATA[Thanks. Live in Chicago so that may be an issue. If it peels over the winter and into Spring will I need to strip off everything and start over?]]></description>
                        <content:encoded><![CDATA[Thanks. Live in Chicago so that may be an issue. If it peels over the winter and into Spring will I need to strip off everything and start over?]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>wooddeck1</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10306</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10298</link>
                        <pubDate>Thu, 13 Aug 2015 11:35:06 +0000</pubDate>
                        <description><![CDATA[Sorry did not see that. Leave it alone. I am concerned that your Thompsons is over applied. It looks like it dried on top of the surface which means it will most likely peel if you live in a...]]></description>
                        <content:encoded><![CDATA[Sorry did not see that. Leave it alone. I am concerned that your Thompsons is over applied. It looks like it dried on top of the surface which means it will most likely peel if you live in a cold weather state. You may have also stained too quickly and did not let the wood weather. More then likely you will need to redo this next year and adding more now will make that even more difficult.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10298</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10297</link>
                        <pubDate>Wed, 12 Aug 2015 19:23:35 +0000</pubDate>
                        <description><![CDATA[Thompsons WaterSeal
	Waterproofer Plus Tinted Wood Protector
	HoneyGold]]></description>
                        <content:encoded><![CDATA[Thompsons WaterSeal<br />
	Waterproofer Plus Tinted Wood Protector<br />
	HoneyGold]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10297</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10292</link>
                        <pubDate>Wed, 12 Aug 2015 14:05:05 +0000</pubDate>
                        <description><![CDATA[You did not answer our question. What stain did you use? It is probably fine though.]]></description>
                        <content:encoded><![CDATA[You did not answer our question. What stain did you use? It is probably fine though.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10292</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10291</link>
                        <pubDate>Wed, 12 Aug 2015 13:37:02 +0000</pubDate>
                        <description><![CDATA[Any suggestions?]]></description>
                        <content:encoded><![CDATA[Any suggestions?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10291</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10286</link>
                        <pubDate>Tue, 11 Aug 2015 13:20:57 +0000</pubDate>
                        <description><![CDATA[Quote from administrator on August 11, 12:53
	What did you use to stain this? 
	Thompsons WaterSeal
	Waterproofed Plus Tinted Wood Protector
                        <content:encoded><![CDATA[<blockquote><strong>Quote from administrator on August 11, 12:53</strong><br />
	What did you use to stain this? </blockquote>
	Waterproofed Plus Tinted Wood Protector<br />
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10286</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10285</link>
                        <pubDate>Tue, 11 Aug 2015 12:53:18 +0000</pubDate>
                        <description><![CDATA[What did you use to stain this?]]></description>
                        <content:encoded><![CDATA[What did you use to stain this?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10285</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10284</link>
                        <pubDate>Tue, 11 Aug 2015 00:14:05 +0000</pubDate>
                        <description><![CDATA[Wondering if I messed up too. I stained my new deck two days ago. It rained one night later and earlier today. The color to very nicely but I&#039;m not sure what a &quot;good job&quot; should look like. I...]]></description>
                        <content:encoded><![CDATA[Wondering if I messed up too. I stained my new deck two days ago. It rained one night later and earlier today. The color to very nicely but I'm not sure what a "good job" should look like. I have some right beading and some longer pooling of water. Any advice? <br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2015/08/jk617-image.jpg" alt="" />]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/i-messed-up-i-think/#post-10284</guid>
