									Desk Bare Spots - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/desk-bare-spots/</link>
            <lastBuildDate>Fri, 18 Sep 2026 14:16:56 +0000</lastBuildDate>
                        <title>RE: Desk Bare Spots</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/desk-bare-spots/#post-14399</link>
                        <pubDate>Wed, 17 May 2023 16:35:05 +0000</pubDate>
                        <description><![CDATA[It is not going to be possible to blend bare spots with any deck stain brand and type. When they occur, it will time to do a full restoration.
These are our top stain brands:]]></description>
                        <content:encoded><![CDATA[<p>It is not going to be possible to blend bare spots with any deck stain brand and type. When they occur, it will time to do a full restoration.</p>
<p>These are our top stain brands: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/desk-bare-spots/#post-14399</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/desk-bare-spots/#post-14398</link>
                        <pubDate>Wed, 17 May 2023 16:27:11 +0000</pubDate>
                        <description><![CDATA[Thank you for your prompt, professional reply.  I need to better understand what type of deck stain to buy then for the future.  If I completely sand the entire deck, what type/brand of deck...]]></description>
                        <content:encoded><![CDATA[<p>Thank you for your prompt, professional reply.  I need to better understand what type of deck stain to buy then for the future.  If I completely sand the entire deck, what type/brand of deck seal should I purchase in order to have it blend the bare spots if they occur.  Thank you.</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>phantom</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/desk-bare-spots/#post-14398</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/desk-bare-spots/#post-14391</link>
                        <pubDate>Tue, 16 May 2023 22:40:49 +0000</pubDate>
                        <description><![CDATA[Not possible to spot fix a semi-transparent deck stain and then have it blend. You would have to remove all old stain and start over with an even coat.]]></description>
                        <content:encoded><![CDATA[<p>Not possible to spot fix a semi-transparent deck stain and then have it blend. You would have to remove all old stain and start over with an even coat.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/desk-bare-spots/#post-14391</guid>
                        <title>Desk Bare Spots</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/desk-bare-spots/#post-14388</link>
                        <pubDate>Tue, 16 May 2023 15:31:52 +0000</pubDate>
                        <description><![CDATA[Used BeautiTone Wood Shield Best Deck Stain 5 years ago (refer to photo for this product).  Pressure washed and recoated it 2 years ago using a paint sprayer.  Incurred no problems, looked g...]]></description>
                        <content:encoded><![CDATA[1504
<p>Used BeautiTone Wood Shield Best Deck Stain 5 years ago (refer to photo for this product).  Pressure washed and recoated it 2 years ago using a paint sprayer.  Incurred no problems, looked great.  Now 2 years later I have a few bare spots where it has peeled off.  This area gets direct sunlight.  I lightly sanded it using 240 grit sand paper, then cleaned that small test area.  I wanted to only do a small test area first to see if my logic worked.  I applied 2 coats on this bare area using a paint brush, waiting 24 hours until I applied the second coat.</p>
<p>My problem is that this bare area hardly changed color at all.  It basically still looks bare with a very light coating of deck stain that looks more like transparent which this color is not.  So after my 2 coats I went back to the hardware store and had them mix my can using their machine.  I then tried another small bare spot area using the same procedure as above.  Same problem, the colored stain barely covers that bare spot.  Any suggestions please.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/desk-bare-spots/#post-14388</guid>
