									Deck&#039;s a mess - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/</link>
            <lastBuildDate>Wed, 16 Sep 2026 12:00:34 +0000</lastBuildDate>
                        <title>RE: Deck&#039;s a mess</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13824</link>
                        <pubDate>Tue, 18 May 2021 13:12:32 +0000</pubDate>
                        <description><![CDATA[Easiest is to replace the wood, but that is also the costliest.]]></description>
                        <content:encoded><![CDATA[<p>Easiest is to replace the wood, but that is also the costliest.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13824</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13823</link>
                        <pubDate>Tue, 18 May 2021 10:48:06 +0000</pubDate>
                        <description><![CDATA[What would you consider the &#039;easiest&#039; approach to fixing the deck.
1. sand the grey side and prep
2. try and sand the joint stains off and prep
3. just buy new wood and start over
I put ...]]></description>
                        <content:encoded><![CDATA[<p>What would you consider the 'easiest' approach to fixing the deck.</p>
<p>1. sand the grey side and prep</p>
<p>2. try and sand the joint stains off and prep</p>
<p>3. just buy new wood and start over</p>
<p>I put these boards down about 5-6 years ago.  I could do it again.  What would you consider the easiest and fastest approach?</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>DreamDeck</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13823</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13822</link>
                        <pubDate>Mon, 17 May 2021 14:05:23 +0000</pubDate>
                        <description><![CDATA[Crown side does not matter so much, but you may not be able to get those joist stains out of the wood. It is deep into the grain.]]></description>
                        <content:encoded><![CDATA[<p>Crown side does not matter so much, but you may not be able to get those joist stains out of the wood. It is deep into the grain.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13822</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13821</link>
                        <pubDate>Mon, 17 May 2021 14:01:40 +0000</pubDate>
When I initially put the boards down, I put the &#039;crown&#039; side up (the wood grain at the end would have a frown). 
I&#039;m not wondering if I could just flip the boards over, sand...]]></description>
                        <content:encoded><![CDATA[<p>@administrator</p>
<p>When I initially put the boards down, I put the 'crown' side up (the wood grain at the end would have a frown). </p>
<p>I'm not wondering if I could just flip the boards over, sand, clean, brighten, and then re-stain.  The crown of the wood would facing down.  What do you think? Is that a bad practice to put the crown side down.  Here are a few pics. This looks like it would be so much easier if the downsides are not too bad.  </p>
1246
1247
<p>Thanks! Chris</p>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13821</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13640</link>
                        <pubDate>Mon, 25 Jan 2021 23:47:43 +0000</pubDate>
                        <description><![CDATA[A stripper will not remove a solid stain fully. You can use it to remove some or possibly most but you will still need to sand to get it all off.]]></description>
                        <content:encoded><![CDATA[A stripper will not remove a solid stain fully. You can use it to remove some or possibly most but you will still need to sand to get it all off.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13640</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13639</link>
                        <pubDate>Mon, 25 Jan 2021 23:09:48 +0000</pubDate>
                        <description><![CDATA[The grey is a solid stain.  Yuck on sanding.  Would it be worth trying to strip this off with one of your products?]]></description>
                        <content:encoded><![CDATA[The grey is a solid stain.  Yuck on sanding.  Would it be worth trying to strip this off with one of your products?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13639</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13638</link>
                        <pubDate>Mon, 25 Jan 2021 19:23:39 +0000</pubDate>
                        <description><![CDATA[The gray looks like a solid stain and that means you probably cannot strip it. You may need to sand it all off to fix this.]]></description>
                        <content:encoded><![CDATA[The gray looks like a solid stain and that means you probably cannot strip it. You may need to sand it all off to fix this.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13638</guid>
                        <title>Deck&#039;s a mess</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13637</link>
                        <pubDate>Mon, 25 Jan 2021 18:43:20 +0000</pubDate>
                        <description><![CDATA[About 4-5 years ago, my deck was stained with an oil based TWP product. Last year, a I hired someone to restain. Unfortunately, they used a water based Sherwin Williams stain. Now I have pat...]]></description>
                        <content:encoded><![CDATA[About 4-5 years ago, my deck was stained with an oil based TWP product. Last year, a I hired someone to restain. Unfortunately, they used a water based Sherwin Williams stain. Now I have patches of the deck where the old stain is bleeding through. It looks terrible. 
I was planning on using Restore a Deck product with the enhancers (will this product strip both stains?) 1193 . When I go do restain, should I use an oil-based or a water-based stain.  Which product on your site would you recommend?
Thanks!]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/decks-a-mess/#post-13637</guid>
