									deck Stain Choices - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/</link>
            <lastBuildDate>Mon, 28 Sep 2026 05:36:26 +0000</lastBuildDate>
                        <title>RE: deck Stain Choices</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13816</link>
                        <pubDate>Sun, 16 May 2021 11:21:52 +0000</pubDate>
                        <description><![CDATA[Humidity does not matter and temps vary based on the brand you are going to use.]]></description>
                        <content:encoded><![CDATA[<p>Humidity does not matter and temps vary based on the brand you are going to use.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13816</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13815</link>
                        <pubDate>Sun, 16 May 2021 06:32:17 +0000</pubDate>
                        <description><![CDATA[when is the best time of year to oil stain a deck? I live in north Carolina with hot humid weather coming soon , what is the best humity that stain will dry and not be Sticky]]></description>
                        <content:encoded><![CDATA[<p>when is the best time of year to oil stain a deck? I live in north Carolina with hot humid weather coming soon , what is the best humity that stain will dry and not be Sticky </p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>Shawdriver</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13815</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13809</link>
                        <pubDate>Fri, 14 May 2021 06:12:12 +0000</pubDate>
                        <description><![CDATA[@administrator ok Thank you for your help anyway.   Randy]]></description>
                        <content:encoded><![CDATA[<p>@administrator ok Thank you for your help anyway.   Randy</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13809</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13805</link>
                        <pubDate>Thu, 13 May 2021 10:46:16 +0000</pubDate>
                        <description><![CDATA[You cannot apply more than 2 coats and you cannot create a distressed look with deck stains. You also cannot mix different brand and different types of stains into your application. What you...]]></description>
                        <content:encoded><![CDATA[<p>You cannot apply more than 2 coats and you cannot create a distressed look with deck stains. You also cannot mix different brand and different types of stains into your application. What you want to do is not possible. Sorry.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13805</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13804</link>
                        <pubDate>Thu, 13 May 2021 06:13:18 +0000</pubDate>
                        <description><![CDATA[@administrator,So based on my Questions you fill the 2 stains can overlap each other and should I let the first coat dry before 2nd and 3rd or should i apply over stain that is still wet and...]]></description>
                        <content:encoded><![CDATA[<p>@administrator,So based on my Questions you fill the 2 stains can overlap each other and should I let the first coat dry before 2nd and 3rd or should i apply over stain that is still wet and blend in? another thought was to apply oil based stain then a second and 3rd coat of oil based paint to get the Stress look I'm looking for. Do you know how Stains and paint interact with each other? Thank you</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13804</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13797</link>
                        <pubDate>Wed, 12 May 2021 10:30:04 +0000</pubDate>
                        <description><![CDATA[Try TWP 100 Series or Armstrong Clark Stains for this deck. Both are excellent penetrating oil-based semi-transparent stains.]]></description>
                        <content:encoded><![CDATA[<p>Try TWP 100 Series or Armstrong Clark Stains for this deck. Both are excellent penetrating oil-based semi-transparent stains.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13797</guid>
                        <title>deck Stain Choices</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13796</link>
                        <pubDate>Wed, 12 May 2021 09:53:29 +0000</pubDate>
                        <description><![CDATA[So I am doing a complete deck Restoration on a 20 year old neglected deck. I live in North Carolina I have a 350 sq foot Deck that receives Moring sun and Afternoon Shade, Summer months are ...]]></description>
                        <content:encoded><![CDATA[<p>So I am doing a complete deck Restoration on a 20 year old neglected deck. I live in North Carolina I have a 350 sq foot Deck that receives Moring sun and Afternoon Shade, Summer months are hot and Humid! My choice of Stain Would be oil Based Semi Transparent. Our Backyard has a Country Cottage Theme That we Just Love! Because of this I want to be Unique and Creative on my Stain and Colors. Typically you see the Same Old deck Over and Over.. I Tore down the wood Blasster  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-stain-choices-2/#post-13796</guid>
