									Deck ready to stain? - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-ready-to-stain/</link>
            <lastBuildDate>Sat, 10 Oct 2026 14:43:07 +0000</lastBuildDate>
                        <title>Deck ready to stain?</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-ready-to-stain/#post-9873</link>
                        <pubDate>Tue, 14 Apr 2015 10:07:17 +0000</pubDate>
                        <description><![CDATA[1. Yes I would replace the screws where you can.
	2. Too smooth and it will not absorb very well. Try the 60 grit and use a deck cleaner/brightener after the sanding to remove sand dust and...]]></description>
                        <content:encoded><![CDATA[1. Yes I would replace the screws where you can.<br />
	2. Too smooth and it will not absorb very well. Try the 60 grit and use a deck cleaner/brightener after the sanding to remove sand dust and swell the pores.<br />
	3. Yes<br />
	4. Maybe. Old trick and not sure as to the effectiveness<br />
	5. Honeytone is lighter then the 101. Darker colors do not hide imperfections but can offer slightly better UV resistance.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-ready-to-stain/#post-9873</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-ready-to-stain/#post-9872</link>
                        <pubDate>Tue, 14 Apr 2015 02:23:36 +0000</pubDate>
                        <description><![CDATA[I’ve finished stripping and brightening my deck in preparation to stain with TWP-100.  Also sanded the railings with 80 grit.  Attached is a photo of the stripped/brightened flooring.  Plann...]]></description>
                        <content:encoded><![CDATA[I’ve finished stripping and brightening my deck in preparation to stain with TWP-100.  Also sanded the railings with 80 grit.  Attached is a photo of the stripped/brightened flooring.  Planned to sand with a rented orbital deck sander, but have quite a few un-recessed screw head, which are Phillips, and can’t be tightened further.  I did a few boards with a hand orbital sander, and calculate I can do the deck in about 8 hours.  Here are my questions.<br />
	1.   Is it worthwhile to replace any screws I can remove with T-25 star drive screws?  Some heads are stripped and I can’t get them out easily.  Any suggestions.<br />
	2.  Used 80 grit on the orbital sander on test floor boards and it made them pretty smooth.  Will this make the stain less likely to absorb.  Can I use 60 grit or courser?<br />
	3.  After sanding, use a cleaner or brightener?<br />
	4.  If I swab the deck with Acetone just before staining, will it make the stain absorb better?<br />
	5.  Finally, considering TWP101 Cedartone color for the deck.  Would a darker tone like TWP115 Honeytone or TWP120 cover imperfections better and provide better UV protection?<br />
	Great forum, thanks for all your help. <br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2015/04/w9q8m-P4130099.JPG" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2015/04/6239i-P4130101.JPG" alt="" />]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>FFWINO</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/deck-ready-to-stain/#post-9872</guid>
