									Can you use water-based stain after previous oil-based stain used? - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/can-you-use-water-based-stain-after-previous-oil-based-stain-used/</link>
            <lastBuildDate>Thu, 27 Aug 2026 06:20:13 +0000</lastBuildDate>
                        <title>RE: Can you use water-based stain after previous oil-based stain used?</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/can-you-use-water-based-stain-after-previous-oil-based-stain-used/#post-11814</link>
                        <pubDate>Fri, 08 Jun 2018 10:36:16 +0000</pubDate>
                        <description><![CDATA[That&#039;s is not true and will ruin the deck stain. Bad advice from This Old House episode.]]></description>
                        <content:encoded><![CDATA[<p>That's is not true and will ruin the deck stain. Bad advice from This Old House episode.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/can-you-use-water-based-stain-after-previous-oil-based-stain-used/#post-11814</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/can-you-use-water-based-stain-after-previous-oil-based-stain-used/#post-11812</link>
                        <pubDate>Fri, 08 Jun 2018 03:49:53 +0000</pubDate>
                        <description><![CDATA[Thank you.  I have heard that some people put a small amount of polyurethane into the oil-based stain to make it stronger and to help it last a little longer.  Do you recommend this?  If so,...]]></description>
                        <content:encoded><![CDATA[<p>Thank you.  I have heard that some people put a small amount of polyurethane into the oil-based stain to make it stronger and to help it last a little longer.  Do you recommend this?  If so, how much?</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>Brian</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/can-you-use-water-based-stain-after-previous-oil-based-stain-used/#post-11812</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/can-you-use-water-based-stain-after-previous-oil-based-stain-used/#post-11805</link>
                        <pubDate>Wed, 06 Jun 2018 21:35:40 +0000</pubDate>
                        <description><![CDATA[2-3 years is the max you will get. Honeytone is the lightest tint inf the TWP and will always fade the fastest. For better UV protection, use a darker or richer color. To switch brands, you ...]]></description>
                        <content:encoded><![CDATA[<p>2-3 years is the max you will get. Honeytone is the lightest tint inf the TWP and will always fade the fastest. For better UV protection, use a darker or richer color. To switch brands, you will need to strip off the TWP.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/can-you-use-water-based-stain-after-previous-oil-based-stain-used/#post-11805</guid>
                        <title>Can you use water-based stain after previous oil-based stain used?</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/can-you-use-water-based-stain-after-previous-oil-based-stain-used/#post-11804</link>
                        <pubDate>Wed, 06 Jun 2018 17:42:16 +0000</pubDate>
                        <description><![CDATA[We live in Virginia and have a pressure-treated pine deck around a pool (salt-water) that receives mostly full sun.  It was built in 2013.  We applied TWP 1500 Honeytone in 2013 and again in...]]></description>
                        <content:encoded><![CDATA[<p>We live in Virginia and have a pressure-treated pine deck around a pool (salt-water) that receives mostly full sun.  It was built in 2013.  We applied TWP 1500 Honeytone in 2013 and again in 2015 (after using the Restore-A-Deck cleaner.)  I am a little disappointed that the TWP stain didn't last longer (2 years is about the longest we should wait between re-staining) and we have had mildew on the rails, especially the horizontal portions and some green algae in a few places.  Do you have a recommendation for a different stain that would last longer and perform better?  I saw the newer reviews for Restore-A-Deck stain and wasn't sure if I could use a water-based stain after having used an oil-based stain in the past. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/can-you-use-water-based-stain-after-previous-oil-based-stain-used/#post-11804</guid>
