									beading on deck - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/beading-on-deck/</link>
            <lastBuildDate>Mon, 12 Oct 2026 19:30:01 +0000</lastBuildDate>
                        <title>beading on deck</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/beading-on-deck/#post-9337</link>
                        <pubDate>Sat, 12 Jul 2014 11:28:42 +0000</pubDate>
                        <description><![CDATA[Did the over application the rails dry completely? If so I would let it be. When doing floors apply two coats wet on wet. 
	If you want to remove from rails you would strip and brighten ...]]></description>
                        <content:encoded><![CDATA[Did the over application the rails dry completely? If so I would let it be. When doing floors apply two coats wet on wet. <br />
	If you want to remove from rails you would strip and brighten for prep.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/beading-on-deck/#post-9337</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/beading-on-deck/#post-9331</link>
                        <pubDate>Fri, 11 Jul 2014 17:00:53 +0000</pubDate>
                        <description><![CDATA[TWP rather.
	If I strip the rails and then sand them? Brightner?]]></description>
                        <content:encoded><![CDATA[TWP rather.<br />
	If I strip the rails and then sand them? Brightner?<br />
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>xfactor70</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/beading-on-deck/#post-9331</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/beading-on-deck/#post-9330</link>
                        <pubDate>Fri, 11 Jul 2014 11:54:03 +0000</pubDate>
                        <description><![CDATA[Hi there. I recently stained with TPW 100 and 1500 combined and put 2 coats on, but the stain appeared WET in a lot of areas and DRY in others..blotchy. I think I put the coats on too heavy....]]></description>
                        <content:encoded><![CDATA[Hi there. I recently stained with TPW 100 and 1500 combined and put 2 coats on, but the stain appeared WET in a lot of areas and DRY in others..blotchy. I think I put the coats on too heavy...I put a 3rd coat on and now water BEADS on the wood.<br />
	I haven't stained the floor decking yet just the railings.<br />
	Can I strip/sand the rails and stain again before staining the floor boards?<br />
	Thank you..please advise.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/beading-on-deck/#post-9330</guid>
