									Armstrong Clark Redwood Tone Failure - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/</link>
            <lastBuildDate>Fri, 16 Oct 2026 11:03:51 +0000</lastBuildDate>
                        <title>RE: Armstrong Clark Redwood Tone Failure</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/#post-11087</link>
                        <pubDate>Wed, 03 May 2017 15:35:35 +0000</pubDate>
                        <description><![CDATA[Not sure. Could just be your tree was shedding dirt last season? Sounds strange but we have seen decks turn dirty under trees one year and not others. Not sure if using a different brand wou...]]></description>
                        <content:encoded><![CDATA[<p>Not sure. Could just be your tree was shedding dirt last season? Sounds strange but we have seen decks turn dirty under trees one year and not others. Not sure if using a different brand would have made a difference or not. Would not hurt to try something else like the TWP 1500 this time.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/#post-11087</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/#post-11086</link>
                        <pubDate>Wed, 03 May 2017 15:08:21 +0000</pubDate>
                        <description><![CDATA[It&#039;s now spring and the deck looks a lot worse. Looks like you were right it is dirt possibility from the trees. I can only remove it with a power washer. My question is why did this never h...]]></description>
                        <content:encoded><![CDATA[<p>It's now spring and the deck looks a lot worse. Looks like you were right it is dirt possibility from the trees. I can only remove it with a power washer. My question is why did this never happen with the water based Sikkens? Also do you think it will be this bad with TWP 1500? Any other stain you'd recommend besides AC for a dirt/tree problem?</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>pauls</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/#post-11086</guid>
                        <title>Armstrong Clark Redwood Tone Failure</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/#post-10911</link>
                        <pubDate>Mon, 10 Oct 2016 09:48:46 +0000</pubDate>
                        <description><![CDATA[It is not sun damage. Try taking a wet towel and just rub a very small spot. The towel will most likely have dirt on it after.
	You could try the AC in a darker semi-solid. You might wan...]]></description>
                        <content:encoded><![CDATA[It is not sun damage. Try taking a wet towel and just rub a very small spot. The towel will most likely have dirt on it after.<br />
	You could try the AC in a darker semi-solid. You might want to go with a color that is more "brown" next time, so the dirt, etc will not show as much.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/#post-10911</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/#post-10910</link>
                        <pubDate>Mon, 10 Oct 2016 07:23:30 +0000</pubDate>
                        <description><![CDATA[Dirt?? I assumed it was sun damage especially since under the grill where it&#039;s shady looks ok. Will a semi solid stain help? What stain would you use next?]]></description>
                        <content:encoded><![CDATA[Dirt?? I assumed it was sun damage especially since under the grill where it's shady looks ok. Will a semi solid stain help? What stain would you use next?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/#post-10910</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/#post-10909</link>
                        <pubDate>Mon, 10 Oct 2016 06:40:58 +0000</pubDate>
                        <description><![CDATA[Looks like you are having dirt accumulate on the deck from the trees. You can see where under your grill, it is still clean. You really cannot stop this from happening and using a different ...]]></description>
                        <content:encoded><![CDATA[Looks like you are having dirt accumulate on the deck from the trees. You can see where under your grill, it is still clean. You really cannot stop this from happening and using a different brand of stain would not prevent this either. If you want to switch to TWP, your will need to prep again with the Restore A Deck products.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/#post-10909</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/#post-10908</link>
                        <pubDate>Sun, 09 Oct 2016 18:09:05 +0000</pubDate>
                        <description><![CDATA[This past summer I decided to remove the water based Sikkens stain from my deck because it failed in the area that was in full sun. I used the Restore-A-Deck kit exactly as it is recommended...]]></description>
                        <content:encoded><![CDATA[This past summer I decided to remove the water based Sikkens stain from my deck because it failed in the area that was in full sun. I used the Restore-A-Deck kit exactly as it is recommended on this site and on the kit label. The water based stain was too difficult to remove entirely so I decided to sand the entire deck using 80 grit. Being a perfectionist it ended up taking half the summer to get EVERY bit of stain off. I've been researching stains on your site for over a year and decided to go with the Armstrong Clark transparent redwood tone. I used one coat on the railings and two coats wet on wet for the floor. When it was finished, the deck looked ok except I didn't care for how the grain in the wood came out really dark. Now only THREE months later the deck looks horrible!! All the areas in full sun have turned black in only three months! When I was done sanding this deck it looked brand new. I could never sand it again like I did- it's way too much work. <br />
	    Any ideas on why it happened and what options I might have? I was thinking about staining right over the current stain with another oil based stain like TWP. I'm even considering restaining the deck with Armstrong Clarks semi solid stain because it should help with the direct sun. Obviously I'm extremely hesitant to use AC products again and am leaning towards TWP. I'm ruling out solid stains because I'm afraid of the peeling. Any ideas? I've attached before and after pics.  Thank you.<br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2016/10/l86yw-image.jpg" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2016/10/9m3wq-image.jpg" alt="" />]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/armstrong-clark-redwood-tone-failure/#post-10908</guid>
