									Apply clear sealant over old semi-transparent Behr stain without stripping? - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/</link>
            <lastBuildDate>Sat, 03 Oct 2026 16:29:08 +0000</lastBuildDate>
                        <title>RE: Apply clear sealant over old semi-transparent Behr stain without stripping?</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12832</link>
                        <pubDate>Sat, 27 Jul 2019 13:31:53 +0000</pubDate>
                        <description><![CDATA[Any roller should work.]]></description>
                        <content:encoded><![CDATA[<p>Any roller should work.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12832</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12830</link>
                        <pubDate>Sat, 27 Jul 2019 03:09:46 +0000</pubDate>
                        <description><![CDATA[Thank you so much.  Is there a particular roller type that is best for applying a solid stain?]]></description>
                        <content:encoded><![CDATA[<p>Thank you so much.  Is there a particular roller type that is best for applying a solid stain?</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>Maria</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12830</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12828</link>
                        <pubDate>Fri, 26 Jul 2019 10:46:16 +0000</pubDate>
                        <description><![CDATA[You can cover the Behr with the RAD solid stain but not their semi-transparent stain. Use a deck cleaner and pressure washing. Make sure all the stain that you leave in the wood is not peeli...]]></description>
                        <content:encoded><![CDATA[<p>You can cover the Behr with the RAD solid stain but not their semi-transparent stain. Use a deck cleaner and pressure washing. Make sure all the stain that you leave in the wood is not peeling and you will be good to go.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12828</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12826</link>
                        <pubDate>Thu, 25 Jul 2019 21:44:54 +0000</pubDate>
                        <description><![CDATA[Do I use only a cleaner or should I also use a brightener.  Based on your reviews, I am planning on applying a RAD solid stain.  I contacted RAD, and they said their stripper does not take t...]]></description>
                        <content:encoded><![CDATA[<p>Do I use only a cleaner or should I also use a brightener.  Based on your reviews, I am planning on applying a RAD solid stain.  I contacted RAD, and they said their stripper does not take the Behr stain off, and they cannot guarantee that the solid stain will work over the Behr.  Usually they recommend stripping, but in the case of Behr that does  not work. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12826</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12685</link>
                        <pubDate>Sun, 16 Jun 2019 21:33:58 +0000</pubDate>
                        <description><![CDATA[The only way to use another semi-transparent stain is to fully sand and or strip off the Behr. Pressure washing is the best prep for a solid stain. You can use a cleaner while doing this.]]></description>
                        <content:encoded><![CDATA[<p>The only way to use another semi-transparent stain is to fully sand and or strip off the Behr. Pressure washing is the best prep for a solid stain. You can use a cleaner while doing this.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12685</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12684</link>
                        <pubDate>Sun, 16 Jun 2019 21:26:34 +0000</pubDate>
                        <description><![CDATA[Thank you so much for your quick response.  I am afraid to use a pressure washer as it could possibly damage my deck?  What about using the Gemini Restrore-A-Deck kit, which is what you reco...]]></description>
                        <content:encoded><![CDATA[<p>Thank you so much for your quick response.  I am afraid to use a pressure washer as it could possibly damage my deck?  What about using the Gemini Restrore-A-Deck kit, which is what you recommend with a strong deck brush? </p><p>Also, since the current stain is a semi-transparent stain, can I use another semi-transparent stain? </p><p>What about future maintenance?  Will it be sufficient to clean once a year, and re-apply a semi-transparent stain every three years thereafter?  Or, if a solid deck stain is what I should be using for sure, can I just restain it very three years or so? </p><p>I am trying to avoid having to strip the stain in future years.</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12684</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12681</link>
                        <pubDate>Sat, 15 Jun 2019 11:10:51 +0000</pubDate>
                        <description><![CDATA[No, you cannot apply a sealer over a deck stain. Try pressure washing and then using a solid color stain over the Behr:]]></description>
                        <content:encoded><![CDATA[<p>No, you cannot apply a sealer over a deck stain. Try pressure washing and then using a solid color stain over the Behr: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12681</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12680</link>
                        <pubDate>Fri, 14 Jun 2019 17:56:11 +0000</pubDate>
                        <description><![CDATA[I would like to add that the look is not very important to me.  All I want to do is preserve the deck as long as possible.  I don&#039;t mind a natural or greying look.  Just want to maintain the...]]></description>
                        <content:encoded><![CDATA[<p>I would like to add that the look is not very important to me.  All I want to do is preserve the deck as long as possible.  I don't mind a natural or greying look.  Just want to maintain the deck as long as I can, without putting poison in the environment and creating too much work for myself.</p><p>I live in San Francisco a block from the ocean.  The deck gets sun all year round, but we have a lot of fog!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12680</guid>
                        <title>Apply clear sealant over old semi-transparent Behr stain without stripping?</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12679</link>
                        <pubDate>Fri, 14 Jun 2019 17:39:25 +0000</pubDate>
                        <description><![CDATA[My deck is a about 260 square feet and is made of pressure treated pine. In 2013 I treated it with Behr Premium semi-transparent waterproofing stain and sealer. I never liked the sealer. It ...]]></description>
                        <content:encoded><![CDATA[<p>My deck is a about 260 square feet and is made of pressure treated pine. In 2013 I treated it with Behr Premium semi-transparent waterproofing stain and sealer. I never liked the sealer. It looked like the wood is painted in orange. However, I also don't like chemicals, so did not want to strip the deck. Now, 6 years later, I definitely need to do something about maintaining the deck. I would like to apply a clear sealant. Can I just clean the deck and apply a clear sealant? Pictures attached.</p><p>725,726,727,728</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/apply-clear-sealant-over-old-semi-transparent-behr-stain-without-stripping/#post-12679</guid>
