									Used Cabot Problem Solver Primer 1st Time - Deck Cleaning Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/used-cabot-problem-solver-primer-1st-time/</link>
            <lastBuildDate>Sun, 30 Aug 2026 16:06:14 +0000</lastBuildDate>
                        <title>Used Cabot Problem Solver Primer 1st Time</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/used-cabot-problem-solver-primer-1st-time/#post-7697</link>
                        <pubDate>Mon, 09 Jul 2012 23:35:31 +0000</pubDate>
                        <description><![CDATA[RAD stain stripper and any other stain stripper will not completely remove a solid stain effectively. It will get some off but not all.
	Wood putty does not work on outside wood.
	I ...]]></description>
                        <content:encoded><![CDATA[RAD stain stripper and any other stain stripper will not completely remove a solid stain effectively. It will get some off but not all.<br />
	Wood putty does not work on outside wood.<br />
	I would just continue with the same solid color stain. Not a big fan of primer for decks. I do not think it works and can cause peeling issues.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/used-cabot-problem-solver-primer-1st-time/#post-7697</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/used-cabot-problem-solver-primer-1st-time/#post-7695</link>
                        <pubDate>Sat, 07 Jul 2012 19:36:16 +0000</pubDate>
                        <description><![CDATA[Hi, thanks for such an informative site.
	I&#039;m trying to redo the topside and spindles of a 600 sq foot deck with 97 spindles. Underneath is still solid coverage, with no peeling. 
	T...]]></description>
                        <content:encoded><![CDATA[Hi, thanks for such an informative site.<br />
	I'm trying to redo the topside and spindles of a 600 sq foot deck with 97 spindles. Underneath is still solid coverage, with no peeling. <br />
	The first time I used Cabot Problem Solver Primer and Cabot Solid Acrylic Decking Stain. It lasted about 2 years. <br />
	So I'm trying to do a faithful prep job, and started with "DeckStrip" Stain and Finish Remover, and a power washer, and I am getting inconsistent results. (image #1) Some of it is getting down to the wood, and some either the primer or stain won’t budge. <br />
	Today I’ve tried sanding with 60 grit, which will take forever, but same thing, I’m only getting to the primer layer, not the wood. (image #3)<br />
	I don’t care about getting to the wood grain for a look, the bottom of the deck is visible and it doesn’t show there. <br />
	That makes me wonder if I have to use the same product to get them to match, but then am I going to be stuck forever with what seems like something that doesn’t last? I am in four seasons Madison, WI, so it does take plenty of weather. <br />
	If I use a better product, with a solid color that is close, I am fine with that. I purchased Pittsburgh Ultra, but am wondering if it will even take as I am having so much trouble getting down to the wood or if I should purchase something else.  <br />
	Questions: <br />
	Should I invest in the RAD to get a more powerful remover? Will that work to get the primer layer off?<br />
	Should I just get the same primer again and use that as a prep coat? <br />
	If I do the primer route again, do I have to get down to the wood no matter what?<br />
	Product (Stain) you reccommend for this situation? <br />
	Should I use any type of wood putty to seal up the deep cracks that have settled in on the top facing sides of the rail? <br />
	I hope you can answer soon! Am mid-project :)<br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2012/07/q202y-IMG_2376.JPG" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2012/07/99o86-IMG_2377.JPG" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2012/07/9c8q8-IMG_2379.JPG" alt="" />]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>Annie Rubens</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/used-cabot-problem-solver-primer-1st-time/#post-7695</guid>
