									Sanding and brightner ? - Deck Cleaning Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/</link>
            <lastBuildDate>Mon, 09 Nov 2026 17:35:07 +0000</lastBuildDate>
                        <title>Sanding and brightner ?</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/#post-8486</link>
                        <pubDate>Fri, 21 Jun 2013 19:46:53 +0000</pubDate>
                        <description><![CDATA[Great!]]></description>
                        <content:encoded><![CDATA[Great!]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/#post-8486</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/#post-8481</link>
                        <pubDate>Fri, 21 Jun 2013 01:11:47 +0000</pubDate>
                        <description><![CDATA[Thank you very much for explaining the &quot; why &quot; I am a spoiled hardwood floor guy doing a favor for a client. I was contracted for the interior and this deck simply fell in my lap. So between...]]></description>
                        <content:encoded><![CDATA[Thank you very much for explaining the " why " I am a spoiled hardwood floor guy doing a favor for a client. I was contracted for the interior and this deck simply fell in my lap. So between my dustless systems and the final vacuum there would not be enough dust to fill a small cup left behind. I will try to post a pic when we are finished for you.]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>D.P.Hardwoods</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/#post-8481</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/#post-8479</link>
                        <pubDate>Thu, 20 Jun 2013 20:17:01 +0000</pubDate>
                        <description><![CDATA[The cleaner will help remove all the sand dust that you will leave in the pores. Lifts it up so you can wash it out.]]></description>
                        <content:encoded><![CDATA[The cleaner will help remove all the sand dust that you will leave in the pores. Lifts it up so you can wash it out.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/#post-8479</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/#post-8478</link>
                        <pubDate>Wed, 19 Jun 2013 21:43:08 +0000</pubDate>
                        <description><![CDATA[I am missing something. Why would I introduce chemicals to the wood (cleaner) then have to neutralize with the brightner if the material is clean ? I could see the brightner as it&#039;s a liquid...]]></description>
                        <content:encoded><![CDATA[I am missing something. Why would I introduce chemicals to the wood (cleaner) then have to neutralize with the brightner if the material is clean ? I could see the brightner as it's a liquid it would raise the grain and open the pores a bit more for deeper penetration after I sanded and buffed it smooth. What can the cleaner do that my sanding equipment can not achieve ?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/#post-8478</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/#post-8476</link>
                        <pubDate>Wed, 19 Jun 2013 20:25:30 +0000</pubDate>
                        <description><![CDATA[You should use both a deck cleaner and a wood brightener after sanding before applying the TWP.]]></description>
                        <content:encoded><![CDATA[You should use both a deck cleaner and a wood brightener after sanding before applying the TWP.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/#post-8476</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/#post-8475</link>
                        <pubDate>Wed, 19 Jun 2013 16:50:45 +0000</pubDate>
                        <description><![CDATA[I am a wood floor finisher and I have a client with roughly 1500sqft of tongue and grove pine decking he would like sanded and stained as well. The home is located in Michigan so I am thinki...]]></description>
                        <content:encoded><![CDATA[I am a wood floor finisher and I have a client with roughly 1500sqft of tongue and grove pine decking he would like sanded and stained as well. The home is located in Michigan so I am thinking the TWP 100 SERIES. My question is after I sand and buff out the deck is a brightner even needed ? The surface area will be clean and they are choosing a lighter colored stain so I am not sure if I still need to open the grain up further as I am assuming that is part of what a brightner can do.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/sanding-and-brightner/#post-8475</guid>
