									residue from defy deck cleaner + brightener - Deck Cleaning Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/residue-from-defy-deck-cleaner-brightener/</link>
            <lastBuildDate>Sun, 27 Sep 2026 20:27:30 +0000</lastBuildDate>
                        <title>residue from defy deck cleaner + brightener</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/residue-from-defy-deck-cleaner-brightener/#post-9628</link>
                        <pubDate>Mon, 15 Sep 2014 10:42:42 +0000</pubDate>
                        <description><![CDATA[Try washing done again with water to see if you can remove the wood fibers.]]></description>
                        <content:encoded><![CDATA[Try washing done again with water to see if you can remove the wood fibers.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/residue-from-defy-deck-cleaner-brightener/#post-9628</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/residue-from-defy-deck-cleaner-brightener/#post-9627</link>
                        <pubDate>Sun, 14 Sep 2014 21:44:57 +0000</pubDate>
                        <description><![CDATA[I used a pressure washer to rinse the cleaner and a hose to rise the brightener. I have a pressure washer available. Would you recommend washing with a pressure washer?]]></description>
                        <content:encoded><![CDATA[I used a pressure washer to rinse the cleaner and a hose to rise the brightener. I have a pressure washer available. Would you recommend washing with a pressure washer?]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>bootlucky</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/residue-from-defy-deck-cleaner-brightener/#post-9627</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/residue-from-defy-deck-cleaner-brightener/#post-9625</link>
                        <pubDate>Sun, 14 Sep 2014 21:20:27 +0000</pubDate>
                        <description><![CDATA[That is oxidized wood cells that did not get removed completely during the cleaning. Did you use a pressure washer? More then likely if you cannot see this when wet with water then you will ...]]></description>
                        <content:encoded><![CDATA[That is oxidized wood cells that did not get removed completely during the cleaning. Did you use a pressure washer? More then likely if you cannot see this when wet with water then you will not this when stained.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/residue-from-defy-deck-cleaner-brightener/#post-9625</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/residue-from-defy-deck-cleaner-brightener/#post-9623</link>
                        <pubDate>Sun, 14 Sep 2014 13:42:15 +0000</pubDate>
                        <description><![CDATA[Hello,
	based on the recommendations by this website, I went with the Defy wood cleaner and then the defy wood brightener as well. My deck is pressure treated pine and it&#039;s been exposed ...]]></description>
	based on the recommendations by this website, I went with the Defy wood cleaner and then the defy wood brightener as well. My deck is pressure treated pine and it's been exposed to the elements for almost 2 years without stain. I'm finally getting around to things!<br />
	Anyway, after using the wood cleaner (and scrubbing things like crazy) the wood looked great while it was wet. When it dried, it seems to have a whitish film/residue in areas. I figured this would be taken care of by the wood brightener. So, I applied brightener and I see maybe a minor improvement but I definitely still see the white. Again, it looked great while wet, but when it dries it looks like the pictures below. My question is: is this normal? Do I need to do something else before application of the stain? I made sure to rinse a lot because I thought that might be the issue. Also, it rained a lot yesterday and the 3rd picture is after all the rain. Thanks!<br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2014/09/78w89-photo-1.JPG" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2014/09/iquz7-photo-2.JPG" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2014/09/2d17n-photo3.JPG" alt="" />]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/residue-from-defy-deck-cleaner-brightener/#post-9623</guid>
