									Post cleaning and sanding question - Deck Cleaning Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/</link>
            <lastBuildDate>Mon, 05 Oct 2026 08:02:07 +0000</lastBuildDate>
                        <title>RE: Post cleaning and sanding question</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-12499</link>
                        <pubDate>Tue, 30 Apr 2019 14:39:07 +0000</pubDate>
                        <description><![CDATA[Using a deck cleaner and a wood brightener while pressure washing will remove the gray and algae. Use Restore A Deck prep kits.For the stain, try TWP or Armstrong Clark.]]></description>
                        <content:encoded><![CDATA[<p>Using a deck cleaner and a wood brightener while pressure washing will remove the gray and algae. Use Restore A Deck prep kits.</p><p>For the stain, try TWP or Armstrong Clark.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-12499</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-12498</link>
                        <pubDate>Tue, 30 Apr 2019 13:06:32 +0000</pubDate>
                        <description><![CDATA[I purchased a condo which has a seven year old deck which is made of pressure treated lumber, (looks like pine) and has a fair amount of green mildew on the floor area. It also appears to ha...]]></description>
                        <content:encoded><![CDATA[<p>I purchased a condo which has a seven year old deck which is made of pressure treated lumber, (looks like pine) and has a fair amount of green mildew on the floor area. It also appears to have a recently replaced top rail of non-pressure treated white pine which has not been treated, just new wood and it has turned gray. The deck is exposed to full sun in Northern Virginia. There is no cover over the deck. What is the best way to get rid of the gray on the new wood and the best way too "treat" it after getting rid of the gray?</p><p>Also, what should I do about the green mildew on the floor and the best way too "treat" it after getting rid of the mildew?</p><p>Thanks in advance for your advice.</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>deck</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-12498</guid>
                        <title>Post cleaning and sanding question</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-10393</link>
                        <pubDate>Mon, 14 Sep 2015 11:18:03 +0000</pubDate>
                        <description><![CDATA[Quote from lwolf2 on September 13, 15:36
	Hi, I have the same question as Skip above.  How do I start a new post?  ThanksYou register at the top of the forum area then you can create posts ...]]></description>
                        <content:encoded><![CDATA[<blockquote><strong>Quote from lwolf2 on September 13, 15:36</strong><br />
	Hi, I have the same question as Skip above.  How do I start a new post?  Thanks</blockquote>You register at the top of the forum area then you can create posts or threads.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-10393</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-10389</link>
                        <pubDate>Sun, 13 Sep 2015 15:36:37 +0000</pubDate>
                        <description><![CDATA[Hi, I have the same question as Skip above.  How do I start a new post?  Thanks]]></description>
                        <content:encoded><![CDATA[Hi, I have the same question as Skip above.  How do I start a new post?  Thanks]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>lwolf2</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-10389</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-9347</link>
                        <pubDate>Sun, 13 Jul 2014 23:23:48 +0000</pubDate>
                        <description><![CDATA[Thanks, the stain went on no problem and the deck looks great.]]></description>
                        <content:encoded><![CDATA[Thanks, the stain went on no problem and the deck looks great.]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>jimct</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-9347</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-9346</link>
                        <pubDate>Sun, 13 Jul 2014 14:56:33 +0000</pubDate>
                        <description><![CDATA[I apologize ahead of time for this thread hijack, but I wish to ask a question in a new thread, and I can&#039;t see anything that would allow me to do that. No buttons to push, no &quot;Start a new t...]]></description>
                        <content:encoded><![CDATA[I apologize ahead of time for this thread hijack, but I wish to ask a question in a new thread, and I can't see anything that would allow me to do that. No buttons to push, no "Start a new thread", nothing. Is there a waiting period for new members?]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>Skip</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-9346</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-9338</link>
                        <pubDate>Sat, 12 Jul 2014 11:31:49 +0000</pubDate>
                        <description><![CDATA[Not sure what would cause this except some remnants of old stain or sealer. Other option is over sanding? It is possible that if you stain that the TWP does not absorb in those areas and you...]]></description>
                        <content:encoded><![CDATA[Not sure what would cause this except some remnants of old stain or sealer. Other option is over sanding? It is possible that if you stain that the TWP does not absorb in those areas and you can have shiny spots as it dries on top of the wood.<br />
	I do not think you can do much now about it and your prep does seem thorough. We would stain it.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-9338</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-9333</link>
                        <pubDate>Sat, 12 Jul 2014 03:02:02 +0000</pubDate>
                        <description><![CDATA[any thoughts on this?]]></description>
                        <content:encoded><![CDATA[any thoughts on this?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-9333</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-9322</link>
                        <pubDate>Thu, 10 Jul 2014 01:16:39 +0000</pubDate>
                        <description><![CDATA[I stripped my deck, power washed, and used neutralizer.  Then I sanded the  deck with a square buff sander and the railings with an orbital using 60 and 80 grit. The deck is 17 years old and...]]></description>
                        <content:encoded><![CDATA[I stripped my deck, power washed, and used neutralizer.  Then I sanded the  deck with a square buff sander and the railings with an orbital using 60 and 80 grit. The deck is 17 years old and is made out of cedar and the railings PT.  I let it stand for a couple of weeks.  I was washing it down with a hose to get any dirt the had built up on it as I was planing to stain it this weekend with twp 1500.  I noticed some spots on the deck and posts and rails where the water was beading up. Will this prevent the stain from absorbing or cause blotchy spots?  What would cause this?<br />
	Do I need to clean it with something else before I stain or wait longer?<br />
	Thanks,<br />
	Jim]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/post-cleaning-and-sanding-question/#post-9322</guid>
