									NYC Roof Deck Questions - Deck Cleaning Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/</link>
            <lastBuildDate>Tue, 08 Sep 2026 14:41:37 +0000</lastBuildDate>
                        <title>RE: NYC Roof Deck Questions</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12637</link>
                        <pubDate>Wed, 05 Jun 2019 17:16:32 +0000</pubDate>
                        <description><![CDATA[He is wrong. Never sand more than 80 grit. Also, best to not really sand at all. Just clean and brighten after the 3-6 months. You want the wood porous.]]></description>
                        <content:encoded><![CDATA[<p>He is wrong. Never sand more than 80 grit. Also, best to not really sand at all. Just clean and brighten after the 3-6 months. You want the wood porous.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12637</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12636</link>
                        <pubDate>Wed, 05 Jun 2019 15:30:04 +0000</pubDate>
                        <description><![CDATA[I have an update on this and a question that has come up.  We ended up replacing almost all the boards. The contractor wants to sand everything with three passes—60 grit, 80, then 150. He sa...]]></description>
                        <content:encoded><![CDATA[<p>I have an update on this and a question that has come up. </p><p> </p><p>We ended up replacing almost all the boards. The contractor wants to sand everything with three passes—60 grit, 80, then 150. He says that we should do this now to get rid of splinters and also level off variations in height. He says we should also seal and stain right afterwards with an oil-based stain to protect everything. </p><p> </p><p>I explained that we want to use a water-based stain, and our instructions are to let the wood weather for 3-6months first. He said we should still sand it smooth first (in 3 months). I said that anything higher than 60 or 80 grit wasn’t recommended because it blocks the pores from absorbing the stain. </p><p>There are some parts that do need to be sanded, and he’s concerned we need to lower the screw depths and do a deep sanding.</p><p>Can someone please weigh in with specifics on what our recommended next steps should be for sanding and staining?</p><p> </p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>ajb224</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12636</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12546</link>
                        <pubDate>Mon, 13 May 2019 16:54:04 +0000</pubDate>
                        <description><![CDATA[Sounds good!]]></description>
                        <content:encoded><![CDATA[<p>Sounds good!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12546</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12545</link>
                        <pubDate>Mon, 13 May 2019 16:48:59 +0000</pubDate>
                        <description><![CDATA[So would the order be:Replace planksSand*Spray deck with waterApply RAD cleaner with pump sprayerLet sit for 15 mins.Pressure wash at low pressureRinse. Apply RAD brightener with pump spraye...]]></description>
                        <content:encoded><![CDATA[<p>So would the order be:<br /><br /></p><ol><li>Replace planks</li><li>Sand*</li><li>Spray deck with water</li><li>Apply RAD cleaner with pump sprayer</li><li>Let sit for 15 mins.</li><li>Pressure wash at low pressure</li><li>Rinse. </li><li>Apply RAD brightener with pump sprayer</li><li>Let sit for 10 mins.</li><li>Rinse for 20 mins.</li></ol><p>*We have a large orbital floor buffing machine and were thinking of using a 60grit screen on this.</p><p>We would do this again (without the sanding) after the wood is weathered, and then add stain.<br />How does that sound?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12545</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12544</link>
                        <pubDate>Mon, 13 May 2019 16:16:39 +0000</pubDate>
                        <description><![CDATA[No need unless you want to lightly to smooth down some splinters.]]></description>
                        <content:encoded><![CDATA[<p>No need unless you want to lightly to smooth down some splinters.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12544</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12543</link>
                        <pubDate>Mon, 13 May 2019 16:06:50 +0000</pubDate>
                        <description><![CDATA[Thanks so much. What&#039;s your opinion on sanding?]]></description>
                        <content:encoded><![CDATA[<p>Thanks so much. What's your opinion on sanding?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12543</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12542</link>
                        <pubDate>Mon, 13 May 2019 15:26:16 +0000</pubDate>
                        <description><![CDATA[Yes.]]></description>
                        <content:encoded><![CDATA[<p>Yes.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12542</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12541</link>
                        <pubDate>Mon, 13 May 2019 15:15:25 +0000</pubDate>
                        <description><![CDATA[Could we replace boards now and clean and brighten right after, and then in the fall and/or next spring we’ll clean, brighten, stain?]]></description>
                        <content:encoded><![CDATA[<p>Could we replace boards now and clean and brighten right after, and then in the fall and/or next spring we’ll clean, brighten, stain?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12541</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12540</link>
                        <pubDate>Mon, 13 May 2019 14:29:54 +0000</pubDate>
                        <description><![CDATA[if you replace the boards now, you will need 3-4 months of weathering.]]></description>
                        <content:encoded><![CDATA[<p>if you replace the boards now, you will need 3-4 months of weathering.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12540</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12539</link>
                        <pubDate>Mon, 13 May 2019 14:20:09 +0000</pubDate>
                        <description><![CDATA[So clean and brighten now, then replace boards in the fall, and in the spring clean, brighten, and stain? That still leaves us with splintered boards all summer. What if we replace boards no...]]></description>
                        <content:encoded><![CDATA[<p>So clean and brighten now, then replace boards in the fall, and in the spring clean, brighten, and stain? That still leaves us with splintered boards all summer. What if we replace boards now, and clean/brighten/stain in 8 weeks?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/nyc-roof-deck-questions/#post-12539</guid>
