									Need help after cleaning and brightening - Deck Cleaning Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/</link>
            <lastBuildDate>Thu, 09 Jul 2026 06:17:05 +0000</lastBuildDate>
                        <title>RE: Need help after cleaning and brightening</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13671</link>
                        <pubDate>Mon, 01 Mar 2021 14:38:52 +0000</pubDate>
                        <description><![CDATA[Not sure if you will be able to get it out on a fence. Normally when this happens we buff off the fuzzies but that is very hard on vertical wood. You could try the buffing by using a hand bu...]]></description>
                        <content:encoded><![CDATA[<p>Not sure if you will be able to get it out on a fence. Normally when this happens we buff off the fuzzies but that is very hard on vertical wood. You could try the buffing by using a hand buffer: https://www.deckstainhelp.com/wood-fuzzies-furring-on-deck/</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13671</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13669</link>
                        <pubDate>Mon, 01 Mar 2021 02:45:24 +0000</pubDate>
                        <description><![CDATA[@administrator Sorry I wasn&#039;t that clear. I have sanded, but it didn&#039;t work. If I clean and brighten it again will that work?
Or was wondering if you had a grit you would recommend.]]></description>
                        <content:encoded><![CDATA[<p>@administrator Sorry I wasn't that clear. I have sanded, but it didn't work. If I clean and brighten it again will that work?</p>
<p>Or was wondering if you had a grit you would recommend.</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>jturner144</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13669</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13664</link>
                        <pubDate>Sun, 28 Feb 2021 14:06:04 +0000</pubDate>
                        <description><![CDATA[Try sanding.]]></description>
                        <content:encoded><![CDATA[<p>Try sanding.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13664</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13660</link>
                        <pubDate>Sat, 27 Feb 2021 19:12:49 +0000</pubDate>
                        <description><![CDATA[@administrator Using the water didn&#039;t really change anything. Should I use a specific grit for sanding or should I just do the clean and brighten again?]]></description>
                        <content:encoded><![CDATA[<p>@administrator Using the water didn't really change anything. Should I use a specific grit for sanding or should I just do the clean and brighten again?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13660</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13659</link>
                        <pubDate>Wed, 17 Feb 2021 14:31:03 +0000</pubDate>
                        <description><![CDATA[Try water only, but get a little closer to the wood when pressure washing. Basically, you are just trying to remove the oxidation &quot;fuzzies&quot;.]]></description>
                        <content:encoded><![CDATA[<p>Try water only, but get a little closer to the wood when pressure washing. Basically, you are just trying to remove the oxidation "fuzzies".</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13659</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13658</link>
                        <pubDate>Wed, 17 Feb 2021 05:13:54 +0000</pubDate>
                        <description><![CDATA[@administrator I tried some sanding with different grits but most left it still showing. When you say rewash, is that clean and brighten or just water wash?]]></description>
                        <content:encoded><![CDATA[<p>@administrator I tried some sanding with different grits but most left it still showing. When you say rewash, is that clean and brighten or just water wash?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13658</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13657</link>
                        <pubDate>Tue, 16 Feb 2021 19:08:44 +0000</pubDate>
                        <description><![CDATA[If no stain on the wood, then you do not need to remove. Try going over the post by sanding or rewash.]]></description>
                        <content:encoded><![CDATA[<p>If no stain on the wood, then you do not need to remove. Try going over the post by sanding or rewash.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13657</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13656</link>
                        <pubDate>Tue, 16 Feb 2021 18:52:25 +0000</pubDate>
                        <description><![CDATA[@administrator  What does remove all mean? Right now the surface is bare. You mean clean and brighten again and that should fix it?]]></description>
                        <content:encoded><![CDATA[<p>@administrator  What does remove all mean? Right now the surface is bare. You mean clean and brighten again and that should fix it?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13656</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13655</link>
                        <pubDate>Tue, 16 Feb 2021 15:44:07 +0000</pubDate>
                        <description><![CDATA[That is oxidization that was not removed fully. You cannot just spot fix. You would have to remove all and start over.]]></description>
                        <content:encoded><![CDATA[<p>That is oxidization that was not removed fully. You cannot just spot fix. You would have to remove all and start over.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13655</guid>
                        <title>Need help after cleaning and brightening</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13654</link>
                        <pubDate>Mon, 15 Feb 2021 20:08:57 +0000</pubDate>
                        <description><![CDATA[Used RAD Cleaner and Brightener and afterwards have splotchy areas on the fence.  I stained over them in another part of the fence and you can see the splotchy parts come through.
Any sugge...]]></description>
                        <content:encoded><![CDATA[<p>Used RAD Cleaner and Brightener and afterwards have splotchy areas on the fence.  I stained over them in another part of the fence and you can see the splotchy parts come through.</p>
<p>Any suggestions to fix?</p>
1195
1196
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/need-help-after-cleaning-and-brightening/#post-13654</guid>
