									Is this as good as I can get it? - Deck Cleaning Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/</link>
            <lastBuildDate>Fri, 13 Nov 2026 21:58:15 +0000</lastBuildDate>
                        <title>RE: Is this as good as I can get it?</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12216</link>
                        <pubDate>Tue, 18 Sep 2018 20:34:59 +0000</pubDate>
                        <description><![CDATA[8-10 inches.Steps are correct. Do not sand again.]]></description>
                        <content:encoded><![CDATA[<p>8-10 inches.</p><p>Steps are correct. Do not sand again.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12216</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12215</link>
                        <pubDate>Tue, 18 Sep 2018 20:14:52 +0000</pubDate>
                        <description><![CDATA[Appreciate your response, last question (probably) in terms of the finishing process now.I have a 3000psi non variable pressure washer with a wide angle end, how far from the surface of the ...]]></description>
                        <content:encoded><![CDATA[<p>Appreciate your response, last question (probably) in terms of the finishing process now.</p><p>I have a 3000psi non variable pressure washer with a wide angle end, how far from the surface of the deck do you recommend I use this to prevent damage to the wood.</p><p>Would the correct cleaning order be?:</p><ol><li>sweep/leaf blow surface</li><li>stripper</li><li>pressure wash</li><li>brightener</li><li>pressure wash</li><li>wait 48 hrs</li><li>stain</li></ol><p>I did sand the whole deck before to get rid of the semi-solid/solid stain with 60 grid and then lightly went over it with 60 grit. Do I need to do anymore sanding again after the washing cycle?</p><p>Thanks so much!</p><p> </p><p> </p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>Noel</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12215</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12214</link>
                        <pubDate>Tue, 18 Sep 2018 15:16:31 +0000</pubDate>
                        <description><![CDATA[I think Mahogany or Black Walnut would be better for this deck.]]></description>
                        <content:encoded><![CDATA[<p>I think Mahogany or Black Walnut would be better for this deck.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12214</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12213</link>
                        <pubDate>Tue, 18 Sep 2018 15:12:32 +0000</pubDate>
                        <description><![CDATA[I&#039;m looking at the 3 hardwood stains from Armstrong Clark. Would I be able to choose from the Amber, Mahogany or Black Walnut? Or would the Amber be too light?Thanks!]]></description>
                        <content:encoded><![CDATA[<p>I'm looking at the 3 hardwood stains from Armstrong Clark. Would I be able to choose from the Amber, Mahogany or Black Walnut? Or would the Amber be too light?</p><p>Thanks! </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12213</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12212</link>
                        <pubDate>Tue, 18 Sep 2018 13:37:26 +0000</pubDate>
                        <description><![CDATA[Thank you for your response!I will strip, clean and then brighten again.]]></description>
                        <content:encoded><![CDATA[<p>Thank you for your response!</p><p>I will strip, clean and then brighten again.</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12212</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12211</link>
                        <pubDate>Tue, 18 Sep 2018 10:41:21 +0000</pubDate>
                        <description><![CDATA[You have old stain still in the wood. Try stripping and pressure washing to get more out and then brighten the wood. Use an exotic hardwood stain when done. IPE and Hardwood Stain Reviews]]></description>
                        <content:encoded><![CDATA[<p>You have old stain still in the wood. Try stripping and pressure washing to get more out and then brighten the wood. Use an exotic hardwood stain when done. </p><p><a href="https://www.deckstainhelp.com/category/deck-product-reviews/ipe-and-hardwood-stain-reviews/">IPE and Hardwood Stain Reviews</a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12211</guid>
                        <title>Is this as good as I can get it?</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12210</link>
                        <pubDate>Tue, 18 Sep 2018 00:49:53 +0000</pubDate>
                        <description><![CDATA[Hey there,we inherited an unloved and battered mahogany deck. About half had what looked like a solid stain on it, the rest of it the stain had work away and it was patchy.I sanded it all do...]]></description>
                        <content:encoded><![CDATA[<p>Hey there,</p><p>we inherited an unloved and battered mahogany deck. About half had what looked like a solid stain on it, the rest of it the stain had work away and it was patchy.</p><p>I sanded it all down and also cleaned then brightened it.</p><p>There are some dark patches in the shaded area of the deck. Is that water damage? </p><p>What would my choices of stain be for this deck, could I get away with a semi-transparent or would I need to go semi solid to get an even finish?</p><p>Thanks!</p><p>542,540,541</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/is-this-as-good-as-i-can-get-it/#post-12210</guid>
