									Deck brightening problem - Deck Cleaning Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/</link>
            <lastBuildDate>Thu, 18 Jun 2026 00:35:28 +0000</lastBuildDate>
                        <title>RE: Deck brightening problem</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/#post-13052</link>
                        <pubDate>Mon, 07 Oct 2019 15:32:04 +0000</pubDate>
                        <description><![CDATA[Ok thanks I will try one area test to see if it works I am assuming the stain will stain funny with those gray areas as opposed to others]]></description>
                        <content:encoded><![CDATA[<p>Ok thanks I will try one area test to see if it works I am assuming the stain will stain funny with those gray areas as opposed to others</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>bearo7</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/#post-13052</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/#post-13051</link>
                        <pubDate>Mon, 07 Oct 2019 15:32:02 +0000</pubDate>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/#post-13051</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/#post-13050</link>
                        <pubDate>Mon, 07 Oct 2019 14:57:50 +0000</pubDate>
                        <description><![CDATA[You could try the brightener again but the darkness looks internal. Meaning deep in the wood.]]></description>
                        <content:encoded><![CDATA[<p>You could try the brightener again but the darkness looks internal. Meaning deep in the wood. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/#post-13050</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/#post-13049</link>
                        <pubDate>Mon, 07 Oct 2019 14:29:12 +0000</pubDate>
                        <description><![CDATA[It shows darker in those areas with water should I do a Brightener on whole deck again]]></description>
                        <content:encoded><![CDATA[<p>It shows darker in those areas with water should I do a Brightener on whole deck again </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/#post-13049</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/#post-13048</link>
                        <pubDate>Mon, 07 Oct 2019 14:16:13 +0000</pubDate>
                        <description><![CDATA[If it does not show when wet with water then it should not show when you apply the TWP stain.]]></description>
                        <content:encoded><![CDATA[<p>If it does not show when wet with water then it should not show when you apply the TWP stain.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/#post-13048</guid>
                        <title>Deck brightening problem</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/#post-13047</link>
                        <pubDate>Mon, 07 Oct 2019 13:58:48 +0000</pubDate>
                        <description><![CDATA[Hi I recently stripped old stain off sanded and used deck Brightener it looked really good but there were still some gray areas on the cedar gave those areas a second coat now looks even mor...]]></description>
                        <content:encoded><![CDATA[<p>Hi I recently stripped old stain off sanded and used deck Brightener it looked really good but there were still some gray areas on the cedar gave those areas a second coat now looks even more gray any advise on what to do or will it not matter when staining using Twp 1500. 907,905,906,904Thanks </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/deck-brightening-problem/#post-13047</guid>
