									Cleaning after using wrong cleaner - Deck Cleaning Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/cleaning-after-using-wrong-cleaner/</link>
            <lastBuildDate>Sun, 27 Sep 2026 19:59:05 +0000</lastBuildDate>
                        <title>Cleaning after using wrong cleaner</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/cleaning-after-using-wrong-cleaner/#post-9712</link>
                        <pubDate>Tue, 14 Oct 2014 13:36:34 +0000</pubDate>
                        <description><![CDATA[That is oxidation of the wood cells that were not completely removed with the initial cleaning. You can try cleaning again with a little more pressure and a sodium percarbonate based deck cl...]]></description>
                        <content:encoded><![CDATA[That is oxidation of the wood cells that were not completely removed with the initial cleaning. You can try cleaning again with a little more pressure and a sodium percarbonate based deck cleaner. Take not that if you do not see this white fuzz when wet with water then you will most likely not see it when stained.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/cleaning-after-using-wrong-cleaner/#post-9712</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/cleaning-after-using-wrong-cleaner/#post-9711</link>
                        <pubDate>Tue, 14 Oct 2014 13:02:24 +0000</pubDate>
                        <description><![CDATA[I&#039;ve added some pictures to show you what the problem is.
	The first two pictures are after I tried to sand the wood down using a belt sander. The last picture is the floor before sandin...]]></description>
                        <content:encoded><![CDATA[I've added some pictures to show you what the problem is.<br />
	The first two pictures are after I tried to sand the wood down using a belt sander. The last picture is the floor before sanding.<br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2014/10/tks52-image.jpg" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2014/10/l9w3i-image.jpg" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2014/10/yo2zr-image.jpg" alt="" />]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>wrfjrf</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/cleaning-after-using-wrong-cleaner/#post-9711</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/cleaning-after-using-wrong-cleaner/#post-9710</link>
                        <pubDate>Mon, 13 Oct 2014 14:02:24 +0000</pubDate>
                        <description><![CDATA[Please post a picture.]]></description>
                        <content:encoded><![CDATA[Please post a picture.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/cleaning-after-using-wrong-cleaner/#post-9710</guid>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/cleaning-after-using-wrong-cleaner/#post-9707</link>
                        <pubDate>Mon, 13 Oct 2014 03:09:34 +0000</pubDate>
                        <description><![CDATA[Hi, I recently used Olympic deck cleaner and a power washer to clean my pressure treated deck. It did a pretty good job but I did have a lot of extra work to get the old stain off the rim bo...]]></description>
                        <content:encoded><![CDATA[Hi, I recently used Olympic deck cleaner and a power washer to clean my pressure treated deck. It did a pretty good job but I did have a lot of extra work to get the old stain off the rim boards and the posts. Now that I've got that taken care of I learned that I should have used a sodium percarbonate wood deck cleaner instead. I do have a white residue on the wood that I can't seem to get off. I'm concerned it will prevent stain from soaking in correctly. <br />
	My question is, is there a product that would be recommended to re-clean the deck to remove the white residue or should I just try to use a brightener to take care of it or am I out of luck and need just replace the wood now? <br />
	Thanks for your help.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/cleaning-after-using-wrong-cleaner/#post-9707</guid>
