									Buffing to get rid of fuzzies - Deck Cleaning Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/buffing-to-get-rid-of-fuzzies/</link>
            <lastBuildDate>Thu, 24 Sep 2026 05:10:54 +0000</lastBuildDate>
                        <title>RE: Buffing to get rid of fuzzies</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/buffing-to-get-rid-of-fuzzies/#post-13817</link>
                        <pubDate>Sun, 16 May 2021 11:23:06 +0000</pubDate>
                        <description><![CDATA[Floor buffer with sanding pad is the easiest way. It will not reduce absorption. You get the pads at the rental yard. They are either white or red.]]></description>
                        <content:encoded><![CDATA[<p>Floor buffer with sanding pad is the easiest way. It will not reduce absorption. You get the pads at the rental yard. They are either white or red.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/buffing-to-get-rid-of-fuzzies/#post-13817</guid>
                        <title>Buffing to get rid of fuzzies</title>
                        <link>https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/buffing-to-get-rid-of-fuzzies/#post-13814</link>
                        <pubDate>Sat, 15 May 2021 13:47:11 +0000</pubDate>
                        <description><![CDATA[Hello!  I used RAD cleaner/brightener on a new (aged 13 months) deck using scrub brush.  All gray removed and most black (minor left). But now I have the white fuzzies.  I see that you do no...]]></description>
                        <content:encoded><![CDATA[<p>Hello!  I used RAD cleaner/brightener on a new (aged 13 months) deck using scrub brush.  All gray removed and most black (minor left). But now I have the white fuzzies.  I see that you do not recommend sanding before staining, but also recommend buffing to get rid of fuzzies.  So do I just use a floor buffer with buffer pad?  But you also mention a sanding pad.  Difference there?  I want to ensure good stain absorption (DEFY extreme semi-transparent). Will it removing fuzzies reduce some absorption?  What exact pad should I use and with what wait time before staining.  </p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/">Deck Cleaning Questions and Answers</category>                        <dc:creator>mclaugd</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-cleaning-questions-and-answers/buffing-to-get-rid-of-fuzzies/#post-13814</guid>
